Is anyone familiar with the Landpride "Spiked Pulverizer" implement?
   / Is anyone familiar with the Landpride "Spiked Pulverizer" implement? #21
Spiked drag harrow or a tandem disc harrow with all the set taken out. Seed then run a smooth cultipacker.
Good idea. I have used a disc before and it does work if you do a cross check pattern and take it easy. That's an inexpensive option I'd say.
Thanks. As mentioned, I just sold a Brillion overseeder. They are great in theory but for small jobs like I have in mind are awkward, heavy and, because the ground and grass is not perfectly flat, is inconsistent in planting. I only want to do small areas under big trees or small sections of yard that are too labor intensive to tear up and reseed when just adding some seed would work fine.
That slit seeder likely needs new slitters and for that model are around $1,000 and more than a long day to install. Very tight working area and all hand wrenches.. That's why the price is lower than you would think.
A slit seeder is great in an open area but doesn't fit in tight spots. Plus, my 4 ft one was 1500 lbs empty and I needed a bigger tractor to handle it. That bigger tractor made it even more awkward in tight places.
   / Is anyone familiar with the Landpride "Spiked Pulverizer" implement? #24
Just thought I'd throw that out there. I had one of the Woods Pulverizer/Seeders, about 15 years ago. It was 15 years old, but brand new. Got it from the Ohio Turnpike Commission. They'd bought it new to do some seeding along the Turnpike. It was one of 4 they had, and never used. Got it reseed the horse pasture, and hay field. The horses had the pasture barbered down pretty good, so figured I'd try it first. I wasn't impressed with the job it did, so never bothered to do the hayfield. They may do well on seeding a new lawn, I don't know.
Later that summer I found this Olathe slit seeder on CL for $100. It's not pretty, but, works great. Even with new drive chain, and a couple bearings, still have less than $150 in it. Great for in the pasture where the horses have it compacted, even better in the hay field. I never really noticed it not seeding in areas with some dips. First time I used it pictured here, I sowed Timothy, and had a great stand. Probably wouldn't notice it, like on a lawn though. None the less, I would choose this over the Woods anytime. I hope that one works out for you.
DJ54..good comments. On the Woods pulverizer seeder, did you have the one with the spiked angled gangs in front , then a second straight spiked roller and then a packer? What happened if you angled the gangs in sharply and did it allow greater scuffing of the ground? I'm beginning to have doubts on the Woods tool for my use.
Maybe I should consider the one with the discs up front, then a spiked roller and then the packer wheels.
Any more pics of that Olathe seeder?
   / Is anyone familiar with the Landpride "Spiked Pulverizer" implement? #26
Mine was an older version that had big heavy harrow spikes, seed box, then spiked roller on the back. I did a quick check, and found some pics from an equipment site, of one like it. I was the Gill/Woods SU660. Woods SUPER SU66 Air Seeder MGD TRACTOR & EQ., INC. LEBANON Pennsylvania | Fastline This model I found, was definitely made for new seeding. I had in mind, using it when the dirt was pretty dry, but yet, not bone dry. Enough moisture, but not too wet, to scuff up. It basically collected grass on those spikes, and got a pretty decent buildup, instead of ripping through the sod, and opening up, with grass rolling around, like I had pictured how I thought it would work.
That one with the dual angled rollers would probably work a lot better, IF soil conditions were near perfect. I just kinda' question how well they would clean themselves in sod, when not running at a decent clip, to throw it off. I would venture to say, the drier the dirt, the better it would work in sod.
I don't know how large of a lawn you have in mind to repair, but, there are several push slit seeders on Columbus CL right now, for reasonable prices. Toro 2 inch Slit Seeder - farm & garden - by owner - sale overseeder - billygoat - farm & garden - by owner - sale eXmark Ground Logic Bluebird Turfco lawn landscape - farm & garden - by owner - sale Classen Seededer - farm & garden - by owner - sale
It may not be the way you want to go, but if not all that large of an area, it may be easier to use something like this, than all of the work cleaning up the larger unit, as far as vacuuming out seed, etc.
Found a couple more pics of my seeder, saved in my files here. As you can see, the underneath is in pretty decent shape, as far as the slitting knives, drop tubes, and cover disc's. It originally belonged to Pickerington High School. They used it to reseed their football field, until they went with astro turf. The guy I bought it from ,bought it at the school surplus auction, to seed the lawn, for his new house he had built. He never used it in the few years he had it, and it needed to find a new home. The seed box did have a couple holes in it from leaving seed in it, so welded a patch of sheet metal on, to close those spots. The upper part of the box inside, still looks near new, with the seeding rate chart still near new under the lid. It just sat out in the weather for the time they had it. It's in the barn now, and unless there is a catastrophic disaster with it, should last me, the rest of my life.
   / Is anyone familiar with the Landpride "Spiked Pulverizer" implement? #27
Wish I could find something like that for $100:thumbsup:
I had a slit seeder I sold but one with tines like your has would have worked better. Those straight tines are very aggressive at ripping up thatch while mine had the swept back blade that just makes a nice and clean slice in the ground. My use for this would be commercial use and it has to be user friendly and after all the posts am not sure if my original plans will work. Since I see various equipment come up at auction often, maybe I'll just settle back and see what fate brings over the next months or whatever. A golf course going under or school going to astroturf might be the ticket.
You have a desirable slit seeder and should never sell it. For the little use you will give it, it will do an excellent job and will last forever. Thank for the post and info.
EDIT--I might consider using just a small disc harrow with notched blades and then following up with my seeder. I can see where the grass could wind up in the tines. A disc harrow would be fast, clean and trailer well. Still thinking.
Some great posts in this thread that have really been educational, experience based and changed my thinking. There are some pretty smart people here.
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
2011 INTERNATIONAL PROSTAR SLEEPER (A53843)
2011 INTERNATIONAL...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
LOT LOCATIONS (A54313)
2011 JOHN DEERE 323D SKID STEER (A53843)
2011 JOHN DEERE...
