Plywood for concrete forms
   / Plywood for concrete forms #81
Man, this got stupid
Yeah.
If you actually want to know something about it that is correct, ask Rock Knocker a question.​
/pine your post is misleading as it leaves out the first part of the discussion of the water needed for the chemical reaction. Your post is about the excess water remaining in the concrete
Yea, it isn't a very good blog. The fact that cement is a hydrated compound that incorporates water (or OH) in it's structure. There may be excess water in the pour, more likely with lazy finishers without a design mix. A modern high strength design mix may actually have close to zero excess water.
:laughing:
You mean like:??:laughing:
The water/cement ratio (design mix) has to be adjusted for the amount of excess water required for applicable "workability" modern design mixes state a minimum and maximum slump...
Good luck placing a conc. mix (that only has enough water required for the hydration of the cement) in a form and around multiple rebars etc....
So you had an answer and didnt need to ask a question.
Well, good.
   / Plywood for concrete forms #82
Industrial toys
You are correct in forms are easier to clean and reuse if pulled early. Concrete is also easier to patch if green.
Forms will provide some protection against freezing of concrete.
Structurally there are few reasons to pull forms off concrete. Deterioration of forms being only one I can currently think of
   / Plywood for concrete forms #83
Eddie
Do you have adjustable scaffolding you can use to support your roof forms. Or you could use 4x4 post set on horizontal sill plate
   / Plywood for concrete forms #84
No, it's a chemical reaction between the Portland and the lime. Water just keeps the chemical reaction, Cure, to a slower rate. There is no such thing as hydrating in concrete...
Yep. The strongest concrete comes from just dumping bags of dry concrete mix into the forms. It's already dry, so you can strip the forms as soon as they are full.
   / Plywood for concrete forms #85
Hydrating is to always put water into something. Concrete "hydrates" once at the initial stage, then there is no more hydrating.
If you keep it moist, concrete will continue to cure for 50 years. It reaches 90% of design strength in about 28 days. After that curing slows down. If it loses moisture, curing stops.
   / Plywood for concrete forms #86
So yea...portland, lime and water.
What point here are you making?
You are thinking mortar, not concrete. Portland cement is a mix of kilned limestone, fly ash, and other materials. Concrete is made by mixing Portland cement with graded aggregate. Mortar is made by mixing Portland cement with lime and sand.
   / Plywood for concrete forms #87
I have always been a bit confused about curing concrete. It's an isothermic (sp?) reaction. It gives off heat when curing. In the hoover dam they piped through cold water so the concrete would cure. Yet in cold weather, my concrete has taken very long time to harden. You would think, that would hasten the process, not slow it down.
   / Plywood for concrete forms #88
Curing of concrete is exothermic( released heat) .the water is pumped through the concrete to remove excess heat . If there is a large difference between the interior and exterior temperatures the concrete can crack from thermal stress. In large concrete pours this can be a problem.
   / Plywood for concrete forms #89
The documentary I saw years ago, I believe, said that the concrete might never cure had it not been for this cooling measure.
   / Plywood for concrete forms #90
Industrial toys
The cooling measures allowed the concrete to be placed sooner adjacent previously placed concrete. Theoretically concrete will continue to gain strength as long as water is available for continued hydration. 99 percent of ultimate strength is reached within 56 days in most concrete
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56438)
Koyker Loader...
