PTO chipper WoodMaxx new MX-9900
   / PTO chipper WoodMaxx new MX-9900 #41
The Woodmax arrived properly crated without damage.
Shortened the PTO and went to work... I was not there but got a call saying the L3800 seat presence wouldn't let the PTO be engaged unless the operator was in the seat...
Not sure what the work around is other than to by-pass the switch but the tractor is used by employees at times...
When you get a chance can you make a video of it working?
   / PTO chipper WoodMaxx new MX-9900 #42
I can try... it is at my brother's tree farm...
Never uploaded anything but still pictures.
   / PTO chipper WoodMaxx new MX-9900 #43
Just take ratchet strap or bungey cord and go from one side up over seat and down the other side. As long as there is enough tension to hold the seat down it works fine and doesn't compromise safety for your employees. Actually got the idea off the woodmaxx video from there backhoe section
   / PTO chipper WoodMaxx new MX-9900 #44
Plan to be out this weekend... not sure how much chipping will be done as it is the Christmas Tree season kickoff...
Weather was 81 at Santa Cruz yesterday... a couple of days before the temp was done in the 30's...
Just feels strange doing Christmas Trees in 70+ weather!
   / PTO chipper WoodMaxx new MX-9900 #45
Mixed results...
Had some green Christmas trees... Nordmann, Fraser and Fir and the chipper struggled and clogged more than chipped...
These are not huge trees... mostly 6-9' range
I was not there but it was very slow going slogging through.
Any users with suggestions?
   / PTO chipper WoodMaxx new MX-9900 #46
When you say 6-9 inches, is that the trunk size or trunk with trimed branches?
   / PTO chipper WoodMaxx new MX-9900 #48
I've been chipping fir branches 15-20' long, tree tops, everything. Also lots of stuff other than fir. My 8H hasn't clogged yet. But Christmas trees are a lot bushier than naturally growing fir so it's not a fair comparison.
   / PTO chipper WoodMaxx new MX-9900 #49
Not an easy thing- but you might try to chip some hardwood in between firs. I have read that it helps clear the chamber.
   / PTO chipper WoodMaxx new MX-9900 #50
Wondering if the problem is they are simply too green?
This is the first year with the small chipper... typically rent a small commercial mid January for a final clean up.
The thought was to use the PTO chipper as needed during the season when things are slow.
The feed peels more than grabs if this makes sense.
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
