Home shop crack detection?
   / Home shop crack detection? #12
I did a little research last night and was able to find this stuff: Products | Detroit | Weld-Aid You need all three products and they're roughly $10 a can. I placed an order with Grainger and it'll be available on Tuesday. I'll report the results when available.
I have used that product. Seems to work OK.
Excellent. Any problems with shelf life? The literature says only 2 years.
   / Home shop crack detection? #14
Please don't say manga flux because that's prograde stuff that requires special equipment.
Yeah, some engine shops have a U-shaped electromagnet that might even have the MagnaFlux brand on it.
But you may be able to detect cracks in ferrous metal with a strong permanent magnet, too. I like the Neodymium
magnets you can get free from hard drives, or cheap, from China. After you stick your magnet (in a baggie) on the
block in the test area, sprinkle it with sweepings from around your grinder. The lines of magnetic flux become
visible.
   / Home shop crack detection? #16
If doing penetrant testing make sure to follow the directions. You must allow time for the dye to seep into the cracks. Often people who don't know what they are doing don't wait long enough. Magnetic particle testing was "invented" by a machinist who was running a mill of some sort. He noticed that the millings would get attracted to any cracks or joints in the metal he was working on if the metal was magnetized.
   / Home shop crack detection? #17
visible.
Dude found a crack on my sbc I took for machine work with a part out of a junk microwave he had rigged up.
   / Home shop crack detection? #18
You can also take the block to a shop and have them magna flux it. probably cost the same as buying the other product and they have done it many times. On the engine block it also matters where on the block you want to weld. If the cracks are next to a combustion area you will likely not get good results. If it's just outer water jacket or outer part of block no worries. I'd use spray powder on it. Hot spray process. I've done many. Never had a failure. Still depends on where exactly the cracks are and how bad. If it's a spider crack mess I feel for you.
   / Home shop crack detection? #19
Some folks use pure anti freeze as a crack check. You just have to mark the cracks well and then spray the anti freeze out with carb cleaner. Takes a day to be sure.
   / Home shop crack detection? #20
Indeed. If you are going to an engine machine shop anyway for boring, or even hot-tank cleaning, you should
have them do it. They have the tool, and it takes a minute or 2. The charge is minimal in my experience,
since I am there to get other services done.
Using hi-frequency microwaves would be interesting.
Utility Trailer (A52377)
Utility Trailer...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A52377)
2006 Crimson...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
