4320 with water in oil
   / 4320 with water in oil #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
My dad's 4320 ag tractor is getting water in the oil. Not a lot but It is there. It is a 1972 I believe. Are there any places to start looking? Something that is very common problem with this tractor?
Also, does this have sleeved cylinders that may have a leaking o ring?
Thanks
Bill
   / 4320 with water in oil #4
I have pulled the sleeves on a couple of smaller John Deeres in the last few months. On my sleeves there are two o-rings per sleeve. The sleeves on both engines had some pitting and corrosion on the sleeve at the upper o-ring. If water is getting past the o-rings I'll be surprised if the sleeves are serviceable. I think odds are that you will want/need to replace the sleeves.
   / 4320 with water in oil #5
Ditto on possible engine piston liner failure but engine oil cooler or possibly head gasket could be leaking. One can remove engine oil pan then pressurize cooling system to check for liner/o-ring leakage. Has engine coolant been changed regularly or had PH monitored?
No. Has had neither done.
   / 4320 with water in oil #7
A failed engine oil cooler is less common to occur and far more likely to put engine oil into the cooling system than vice-versa.
   / 4320 with water in oil #8
WET sleeves as someone else mentioned. I did my 74 2630 about 5 years ago. Back then the new sleeves pistons bearing and gaskets was around 800 bucks.
UNUSED CHERY INDUSTRIAL 9.5' WORKBENCH (A51248)
UNUSED CHERY...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
UNUSED INDUSTRIAS AMERICA F10 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
