4320 with water in oil
   / 4320 with water in oil #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
My dad's 4320 ag tractor is getting water in the oil. Not a lot but It is there. It is a 1972 I believe. Are there any places to start looking? Something that is very common problem with this tractor?
Also, does this have sleeved cylinders that may have a leaking o ring?
Thanks
Bill
   / 4320 with water in oil #4
I have pulled the sleeves on a couple of smaller John Deeres in the last few months. On my sleeves there are two o-rings per sleeve. The sleeves on both engines had some pitting and corrosion on the sleeve at the upper o-ring. If water is getting past the o-rings I'll be surprised if the sleeves are serviceable. I think odds are that you will want/need to replace the sleeves.
   / 4320 with water in oil #5
Ditto on possible engine piston liner failure but engine oil cooler or possibly head gasket could be leaking. One can remove engine oil pan then pressurize cooling system to check for liner/o-ring leakage. Has engine coolant been changed regularly or had PH monitored?
No. Has had neither done.
   / 4320 with water in oil #7
A failed engine oil cooler is less common to occur and far more likely to put engine oil into the cooling system than vice-versa.
   / 4320 with water in oil #8
WET sleeves as someone else mentioned. I did my 74 2630 about 5 years ago. Back then the new sleeves pistons bearing and gaskets was around 800 bucks.
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2020 COLOMBO TM LOT NUMBER 200 (A53084)
2020 COLOMBO TM...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
