Where to buy shaft end seal for log splitter pump?
   / Where to buy shaft end seal for log splitter pump? #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
So my log splitter is leaking at the end seal on the hydraulic pump. Looks like the factory did a sloppy job installing the coupler that mates with the motor, and the coupler shaft key was rubbing against the shaft end seal on the pump. Finally wore through and I lost hydraulic power yesterday due to aerated fluid, and saw a puddle on the floor this morning. Had to take pump and hoses off to diagnose the problem.
Here's a pic of the seal and the offending key:
The manufacturer doesn't sell the seal separately, so I'd need to spend $120 for a new pump. Anybody know where I could maybe locate a replacement shaft seal? It's got to be a $5-10 part at most.
The seal fits over a 1/2" shaft, and looks to press inside a 1-1/16 to 1-1/8" race, although I need to get calipers out to my barn to measure that measurement accurately. The seal is about 1/4" thick. Seal was held in place with a cir-clip.
I figure this seal is probably a standard part but I haven't seen anything online.
BTW, I have an e-mail into the manufacturer to see if they have a way to get the seal, or maybe comp me a new pump if that is the only solution. Log splitter is less than 3 years old and this is clearly an assembly defect.
Thanks LD1 -- those all seem to have a metal rim, whereas the one I need is rubber (with the metal internal).
Seems to be somewhat close to this one, but not 100% sure because they use mm dimensions and are only ballpark.
Rotary shaft seal OA-12.7X28.57X6.35-FPM from $15.95
| 123Bearing
I went out to the barn with my calipers, and got these measurements:
Pump Shaft: 0.5" on the nose
Outer race/bore that seal plugs into: 1.085-1.1"
Seal thickness: 0.27"
Seal inner diameter (when not stretched over shaft): 0.45"
Seal outer diameter: 1.1"
The seal seems to be a single lip design, with a spring around the lip. However, the outer part of the seal got torn up by the rotating shaft key and I can't say for sure that it wasn't double lip.
   / Where to buy shaft end seal for log splitter pump? #4
Ordering a seal would be my last resort. I’d go to the local Napa first and if that failed the local hydraulic shop.
   / Where to buy shaft end seal for log splitter pump? #5
As long as dimensions are correct....it should seal.
Some have a green or red coating on the metal also. I think C-R (SKF) calls it bore-tite
   / Where to buy shaft end seal for log splitter pump? #6
What brand splitter and pump? Some pump brands should be fairly easy to get parts for.
Here is the pump:
Pump, 13GPM – Dirty Hand Tools
It's marked with their brand, but I would think it's a generic pump. If I could figure out the OEM then I bet seals would be easier to find.
   / Where to buy shaft end seal for log splitter pump? #9
It should have some number printed on the side.
There are plenty of suppliers that can get that part based on the number.
If you need help finding a supplier PM me.
BOBCAT T595 SKID STEER (A52706)
BOBCAT T595 SKID...
Diesel Generator (A55851)
Diesel Generator...
1R SILT FENCE PLOW (A52706)
1R SILT FENCE PLOW...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
UNUSED Hydraulic Thumb Attachment (A47477)
UNUSED Hydraulic...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
