Is Hydraulic Gear Oil All the Same for Tractors?
   / Is Hydraulic Gear Oil All the Same for Tractors? #12
Just to clarify hydraulic oil and gear oil isn稚 the same thing. As for the other issues I don稚 loose much sleep over mixing oils.
Well, on many tractors, it is the same thing.
After reading these posts, I think I better confirm with the dealer before I buy a tractor. Thanks.
   / Is Hydraulic Gear Oil All the Same for Tractors? #14
True. But, hydraulic transmission oil, and 80w gear oil are basically the same thing. And, therefore interchangeable in many applications.
Even 30w engine oil is sometimes used in the same applications.
The only difference is the additives.
There's a chart on the www showing engine oil, gear oils and trans/hyd fluid side by side. Viscosity comparisons are interesting.
On hyd fluids per se, there are 3 basic fluids: Hyd fluid, trans/hyd fluid (JD 303 popular spec) and premium trans hyd fluid, for wet brakes, hydrostats and all the new goodies (JD 20C for a popular spec), and then there are the individual companies additive specs and dino and syn base stocks to consider..............Daaaaaaaaa
   / Is Hydraulic Gear Oil All the Same for Tractors? #15
Yes, I am familiar with that chart, I have posted them.
I don't agree that transmission fluid, and "premium" transmission fluid are two different categories. It's still the same product, with different additives. It simply has evolved, just like anything else.
   / Is Hydraulic Gear Oil All the Same for Tractors? #16
Bottom line is, the answer to the question "as asked", is NO...
SR
   / Is Hydraulic Gear Oil All the Same for Tractors? #17
Stop right there . Do not be adding SAE90 gear oil to a Deere that uses Hy-Gard in the transmission and hydraulics . Not the 都ame?
Oil must be wet clutch compatable .
   / Is Hydraulic Gear Oil All the Same for Tractors? #18
Well then the oils would be different, not the same .
   / Is Hydraulic Gear Oil All the Same for Tractors? #19
Since every brand of oil has different additives, by that logic, every single product would be in a different category. Even when they meet the same standard.
Sorry, but that doesn't make sense.
   / Is Hydraulic Gear Oil All the Same for Tractors? #20
I never said they were interchangeable in ALL applications.
So, stop right there.
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
UNUSED JCT 60" HD HYD CONCRETE MIXER (A51248)
UNUSED JCT 60" HD...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
