Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #11
We have one of those, but I believe it is an old Deering, we used it years ago, I think dad bought it new back in the 50s.
April 2017 pictures.
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #13
I bought an old Fred Cain, I think, that had seen lots of use and needed a few springs, and some tightening up but I can see that this will be a lot of fun to have. I'm planting food plots for wildlife so its not exactly farming, and this will help.
I cleared a small area thick with vines today.
Used Ratchet Rake bucket attachment to drag vines from trees and up to 1-1/4" trunk diameter trees and vine roots from the ground. Then consolidated debris into piles with the Ratchet Rake and towed piles to the burn pit with Dirt Dog Field Cultivator. At the pit, unhooked the debris from the Field Cultivator and used the Ratchet Rake to push debris into the burn pit. I used large loppers to cut some 2-1/2" grape vines which wanted to wrap around tractor wheels at burn pit, rather than release easily from Field Cultivator tines.
Few of these slightly elevated tows weighed less than 500 pounds. Most were 750 pounds or more.
Returning to the newly cleared area, used the Field Cultivator to drag out additional subsurface vines, roots and wild climbing rose corms to 12" depth. Then, with the Field Cultivator tines elevated so they just kerf the ground, rough graded. Next I will use a Disc Harrow to even and smooth the area, followed by TR3 rake for finish work. These stages will occur interspersed by rainfall.
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #15
I found a Fred Caine in the brush and converted it to fit my little 2610. Still playing around with tine numbers. It was a 9 tine unit. Ive dropped it to 3 tines for now. Pulls nice and easy in my heavy clay soil older pasture so it turns out to be a very handy thing to have since its so adaptable to even a smaller tractor. I think Im going to put two more tines on it and see if I can handle that many. It probably will in some of my already worked areas.
General guidance is five (5) tractor horsepower required per tine. Seven (7) tractor horsepower per APP tine is more realistic.
You know your clay, I do not.
Enjoy.
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #17
July 7, 2015
Photo #1 I pushed through thick wild grape vine growth, visible to left and right of track, with tractor and Land Pride RCF2060 Rotary Cutter on July 4, 2015. Impenetrable to a human prior to cut. Yes, this is excellent snake habitat.
Photo #2 First pass with Dirt Dog APP 66-5.
Photo #3 Vegetation pulled from soil after first pass, Photo #2.
Photo #4 same
Photo #5 Second pass with Dirt Dog APP 66-5. Soil mostly clear of roots.
Photo #6 Vegetation pulled from soil after second pass, Photo #5. APP is lifted.
Photo #7 You need to be alert in the woods. Note "WIDOWMAKER" branch detached from tree, suspended in dead vines, poised to crash down. Perhaps 60 pounds in weight.
Photo #8 This food plot was planted with Austrian Iron Peas in March. During April we had practically no rain and germination was poor. Weeds and pasture grass smothered the few Austrian Iron Peas which germinated. I mowed with Land Pride RCF2060 Rotary Cutter on July 4, 2015, pulled through the APP 66-5 today. Before planting my wheat-based winter food plot seed during October, I may or may not Disc Harrow. I may just make a pass with my ETA Landscape Rake with gauge wheels, seed, then roll with my Cultipacker. October conditions will dictate. ( I may sow Buckwheat as a green manure and shade out weeds. )
Photo #9 Same. Soil is moist today but has very little ability to hold moisture, which perks through sand down to Florida aquaifer at about 35' depth. When moist soil is fertile. When dry, SAND. Tines are in the ground 8" to 11".
Photo #10 Same. Field Cultivator is adjusted for maximum depth. When slack is pulled out, and tines in soil are pulled back against springs equal to draft force, chisel points will have just a bit of 'down' angle to them. Field Cultivator "sucks" into soil like a moldboard plow. A later planting of Austrian Iron Peas in adjacent strip. Four hundred acres of unirragated Peanuts beyond the fence.
The Dirt Dog looks like quality, and I think the Fred Cain is of similar quality.
I wish that I had bought either of them!
Instead: I bought a NEW same style cultivator (over the phone), from Ken Sweet, at Sweet Farm equipment in Canmer, Ky.
I asked Ken Sweet if it was good quality, and he assured me that, "they are all about the same"
That is NOT TRUE!
It turned out that the distributor (Darrel Harp Enterprises of Red Bay Alabama) actually imported my cultivator from India.
To put it bluntly, it is a piece of made in India crap.
Ken Sweet offered to take it back, He paid a $210 bulk shipping rate, but would not agree to coordinate return at that same $210 rate. Trucking company quoted me $400 for return shipping.
I'm stuck with it now, but want to warn you not to make a similar mistake!
Trust ONLY your very own eyes!
Do not base buying decisions on dealer/seller BS!
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #18
So... now I'm in the market for a field cultivator. :)
I like the Dirt Dog and Fred Cain styles that are being discussed here, but have some additional questions I'd like to pose to everyone. First, with regard to this style of cultivator, should I assume that increased weight represents a generally higher quality implement? I assume that a bit of additional weight is not going to make much difference in terms of the power it takes a tractor to pull one; that the number of tines and the width of each of those tines will determine how much power I need to pull it. I ask because the DD and FC cultivators are not readily available in my area (PNW) and shipping one from EA would cost $400. What I do have available in the area is Braber, which weighs nearly 20% more than the Dirt Dog Jeff specced out for us: Braber Equipment - Heavy Duty Spring Loaded Tine Cultivator --- even paying tax and the higher price, it would be cheaper than the others discussed here.
Another reason I'm interested in the weight and its affect on performance is that I've found a lightly used 9-tined version for sale at a slight discount. I would neither need nor be able to pull this, but it appears that I could simply remove 2-4 of the tines and have a wider, slightly heavier version of a 5-7 tined version. I could feasibly even sell those tines to defray part of the cost, which would again be cheaper because it is used and because I would pay no tax. This, to me, looks like the sort of equipment that can be assessed used fairly easier. Is any part of my logic flawed here?
I also run across two other types of field cultivators and would like to see what others have to say about them. First, this style is lighter and has no springs. I assume it is just a very light duty version without the customization potential of those discussed above.
These S-tined styles seem to be the most popular. The sales language suggests that the tines vibrate to better destroy clods. They look less durable than the DD/FC style that has been discussed here earlier, and are lighter in weight. Does anyone have ideas to share regarding the various merits and demerits of the S-tined cultivators in relation to the spring loaded cultivators?
Finally, Jeff posted a picture of the tine depth in another thread. How much of that 17 in ground-to-frame tine can you expect to actually embed into the earth? Put another way, if depth is important, what sort of measurements should we expect to see in the tines on a cultivator?
Freep:
I like the Dirt Dog and Fred Cain styles that are being discussed here, but have additional questions to pose.
Field Cultivators constructed like the DD and FC brands, utilize parabolic tine shape and tractor forward motion to pull tines/points into the soil. With Moldboard Plows, this self-sinking action relying on implement orientation is known as "suck" i.e. "plow suck". You regulate Field Cultivator "suck" the same as "plow suck" by adjusting Three Point Hitch Top Link in/out. Additional weight will be positive. While I have never seen a Braber implement, the picture shows a stout piece of equipment.
Another reason I'm interested in the weight and its affect on performance is that I've found a lightly used 9-tined version for sale at a slight discount. I would neither need nor be able to pull this, but it appears that I could simply remove 2-4 of the tines and have a wider, slightly heavier version of a 5-7 tined version. I could feasibly even sell those tines to defray part of the cost, which would again be cheaper because it is used and because I would pay no tax. This, to me, looks like the sort of equipment that can be assessed used fairly easily. Is any part of my logic flawed here?
If the frame is no wider than your rear tire spacing this should be OK.
Personally, buying new, I buy the optimum size/weight gear. For instance, though it would have been easier to order a Fred Cain F/C from everything attachments.com, at the time I was ready to buy ETA offered only a 60" frame width. I needed a 66" frame width, so even though it was a hassle to order the Dirt Dog APP because I had to drive forty miles one way to pick it up from the nearest Dirt Dog dealer, I elected to do so. I remain happy with the decision.
A spring-protected Chisel Plow is a primary cultivation conservation plow. A spring-protected Field Cultivator is a lighter duty primary cultivation conservation plow/aerator, sized for compact tractors. A Row Crop Cultivator is a tertiary cultivation implement for disrupting (little, baby) weeds in soft, moist, well prepared row crop/garden beds.
I use a heavier S-tine Cultivator. This is an another implement for secondary cultivation. The primary "fail safe" point on this springless design is the generic clamp bolts, which are about 75 cents each to replace. The secondary "fail safe" point is the generic clamp itself, about $3.50 each, including shipping. I have shovels, as opposed to points, for dirt contact. I break 3-4 bolts per season, one clamp per season and perhaps one S-tine every-other-season. Strangely, I have never replaced a shovel.
As bolts, clamps and S-tines distort individually, the tines no longer align in a straight row as shown in PHOTO #1. Still cultivates well as draft force resistance aligns spring-tines when sunk. PHOTOS #1 - #4
(Do not expect to use a Braber/DD/FC Field Cultivator for weed disruption. The tines/points are too narrow. Nor can points be replaced with shovels. The tines are too narrow for necessary plow bolts.)
I buy the highest quality equipment, then use it hard at times, if the job requires it.
THREAD LINK: https://www.tractorbynet.com/forums...rd-crossings-modular-tool-bar.html?highlight=
Finally, Jeff posted a picture of the tine depth in another thread. How much of that 17 in ground-to-frame tine can you expect to actually embed into the earth? Put another way, if depth is important, what sort of measurements should we expect to see in the tines on a field cultivator?
My L3560 (R4 tires, inflated with air) pulls the five DD APP tines 14" deep in Florida sandy-loam. It has only failed to penetrate once. That was attempting to aerate a horse compacted dry pasture. In tougher soils, moist soil would be necessary, or in dry soil a true Chisel Plow behind a heavy 100-horsepower tractor. PHOTO #5
Since June 2015 total repairs to the hard used DD/APP has been one (1) tine point, which cost $7.95 plus shipping.
FREEP: A pleasure to consider your well thought out, well paragraphed post.
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #20
Freep
As to what cultivator is best is really dependent one which application you are planning to use it for. If it is deep cultivation/chisel plowing then the Fred Cain style is hands down the best option and many would say probably the only option. If you are looking at weed control for row crops then an S-tine with Danish sweeps will probably be your best bet. For shallow cultivation on a pre-worked seedbed then a C-tine with chisel tips might be your best option.
I have a Fred Cain 3 point cultivator and a mid-mount cultivator with sweeps on an old BF Avery. I love them both but only for certain applications. The Fred Cain digs deep and I use it mainly for ripping in the spring. The Avery is utilized solely for weed control. For weeds I barely want to go no deeper then necessary because every time you roll soil you bring new soil thats full of weed seeds to that perfect environment where they will germinate.
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
HARDEE RD72M LOT IDENTIFIER 145 (A53084)
HARDEE RD72M LOT...
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
