Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES
   / Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES #31
I have an MX5200 and am pulling a Fred Cain 9 shank unit I got from EA. It works just fine under most conditions unless I'm trying to plow wet clay. I would go 9 because even if it struggled during a first tillage it will not on the second. The shanks are removable, and technically you can add extras to the frame, but it was cheaper to get the 9 and possibly use 7 vs going the other way. I do plow in 4wd and have loaded tires all around.
1. I see tool bars with a single bar and tool bars with multiple horizontal bars. But I am a little confused and have really basic questions. Other than the number of items you could mount on one, is there some benefits to having multiple rows of bars?
The greater length of a multiple tool bar implement, the smoother and leveler the output behind the implement will be after one pass.
2. Also on the chisel plows, I **really** see many differences on what people call a chisel plow?
Tractor and implement nomenclature is not very precise. To me, a chisel plow is a conservation plow with a heavy reset spring protecting each shank. For compact tractors other names for this implement are ALL PURPOSE PLOW and FIELD CULTIVATOR.
I have a JD2355 tractor. 2-WD or 4-WD?
John Deere 2355​
John Deere 2355 tractor photo
1987 - 1992
55 Utility Series
Utility tractor
John Deere 2355 Power
Engine64 hp
47.7 kW
Drawbar (claimed)47 hp
35.0 kW
PTO (claimed)55 hp
41.0 kW
Drawbar (tested)46.7 hp
34.8 kW
PTO (tested)55.9 hp
41.7 kW
John Deere 2355 Weight
2WD ROPS Shipping5965 lbs
2705 kg
2WD cab Shipping6945 lbs
3150 kg
4WD ROPS Shipping6637 lbs
3010 kg
4WD cab Shipping7552 lbs
3425 kg
3. I am considering is a single configurable implement for small jobs mainly on my 8-acre hay field. These would be occasional only jobs such as, making a couple of furrows where I have to re-plant tifton tops (plant by hand). Drag something over hard pan soil (red clay) to cut slits in the soil for moisture to soak in some. Scratch in (disc lightly) overseed / rye for the fall. I by no means want to properly renovate with this piece of equipment which would require too heavy duty of an implement here. Years ago, I had a 5-shank renovator. There are places where the soil was looser, and I could get all 5 shanks in, but that was a miracle. So, I used (3) most often and in the harder soil the moisture had to be perfect.
I recommend a seven-shank (2-WD tractor) or nine-shank or twelve-shank (4-WD tractor) All Purpose Plow as cost effective for your applications. Draw only when the soil moisture is perfect.
Where can I get replacement reversible tips and bolts for a Fred Cain spring protected field cultivator? I need nine replacements with (specialized) bolts and appropriate nuts.
eBay:
Correct plow bolt size: 7/16"-14 X 1-3/4"
(#3 plow bolts - 1/3/4" length)
A plow bolt is a type of fastener that is used for making mechanical connections that require a smooth, or flush, surface at the location where the bolt head protrudes. These were so named because of their early use in the manufacture of plows.
While it has been five years since I last purchased a point replacement I am confident the SKU IF210UB will be an exact point replacement.
More Venders:
cultivator point if210 for sale
Contemporary Fred Cain, Bush Hog and Dirt Dog Field Cultivators are identical except for paint.
July 2024​
We are actively purchasing a new property with a 1 acre livestock enclosure, that will get expanded over time, probably into 3-1 acre paddocks. The existing is nothing but sand, with some mixed in scrub oaks, and a few pine trees. So, the way I see it, I will have an opportunity to have no livestock for a period, and try to get some grass going in there. The question really is; for others dealing with sandy soils, and grossly overgrazed pasture;
1) benign neglect; would the existing seed bed, with the existing manure and urine and scattered hay; is just plain rest the best option?
2) take the opportunity to re level, remove stumps and trash trees, and then over seed?
3) just unroll hay, and out it into service?
This question concerns techniques for dealing with sandy soils and grossly overgrazed pasture.
Hooved animals compact soil, even sandy soil, very hard. Leaving the paddocks fallow would require years and years for nature to restore tilth. Rake/aerate your vacant paddocks with an All Purpose Plow mounted on the tractor Three Point Hitch.
Your Kioti CK2610 HST can pull a three tine or four tine APP, depending on soil moisture and root size.
Why be lazy when your total surface is three acres? If you are going to do it, DO IT RIGHT.
Inland Florida farmland is typically very low in nitrogen, OK on potash, which is mined in Florida and low in Phosphorus. In addition pH is usually 7+, which is on the high side, so you will never need lime. Go to IFAS for a soil test. I fertilize with 24-0-11. Most pasture grass in Florida is some form of Bahia. The highly productive Bahia cultivars require fertilizer and water. The unimproved varieties do not but are 50% less productive than the best cultivars properly tended.
Compost everything possible and rake finished compost into the soil with APP.
2) take the animal free opportunity to level paddocks, remove stumps and trash trees, PLOW and then over seed?
YES.
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
