Price Check Price check on Kubota M7060 HDC12
   / Price check on Kubota M7060 HDC12
lpigott,
Great information! Much appreciated:thumbsup:
The 12sp was a no brainer for me just on the extra hyd flow alone. I'll be adding the 3d function also.
Are the regular lights insufficient?
Interesting about the rear window...
   / Price check on Kubota M7060 HDC12 #12
I just paid 36400 for the same tractor and same options including 3rd function.
   / Price check on Kubota M7060 HDC12 #13
lpigott,
If you are doing much work at night I would say they are. The FEL blocks so much of the light with little side coverage. The second forward set makes a big difference. You could save a few $ installing aftermarket LED lights but I wanted a clean look and if I want I can just change bulbs or housings to get even more output however so far I am pleased with the output. As mine is you have 3 sets of lights on 3 separate switches facing forward and one separately switched set on rear.
   / Price check on Kubota M7060 HDC12 #14
If you like the factory lights;you will be amazed what a decent set of LED's look like.I found a set that fit the factory bracket moved the Halogens to the rear.The ones I purchased are 18Watt and you can't look at them.I added LED's to my boat,four wheeler and my son's tractor.
I don't typically use my tractor after dark but they sure are nice when you need them.
We fish walleye at night and I can light my boat up like Christmas in New York if needed.
   / Price check on Kubota M7060 HDC12 #15
Im sorry that was 46400.
I do a lot of work at night, so I'll probably add that option as well. You are right your post did cost me some $$$ :laughing:
Birdman do you remember where you found the set of LEDs that fit?
   / Price check on Kubota M7060 HDC12 #19
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
