Price Check Price check on Kubota M7060 HDC12
   / Price check on Kubota M7060 HDC12
lpigott,
Great information! Much appreciated:thumbsup:
The 12sp was a no brainer for me just on the extra hyd flow alone. I'll be adding the 3d function also.
Are the regular lights insufficient?
Interesting about the rear window...
   / Price check on Kubota M7060 HDC12 #12
I just paid 36400 for the same tractor and same options including 3rd function.
   / Price check on Kubota M7060 HDC12 #13
lpigott,
If you are doing much work at night I would say they are. The FEL blocks so much of the light with little side coverage. The second forward set makes a big difference. You could save a few $ installing aftermarket LED lights but I wanted a clean look and if I want I can just change bulbs or housings to get even more output however so far I am pleased with the output. As mine is you have 3 sets of lights on 3 separate switches facing forward and one separately switched set on rear.
   / Price check on Kubota M7060 HDC12 #14
If you like the factory lights;you will be amazed what a decent set of LED's look like.I found a set that fit the factory bracket moved the Halogens to the rear.The ones I purchased are 18Watt and you can't look at them.I added LED's to my boat,four wheeler and my son's tractor.
I don't typically use my tractor after dark but they sure are nice when you need them.
We fish walleye at night and I can light my boat up like Christmas in New York if needed.
   / Price check on Kubota M7060 HDC12 #15
Im sorry that was 46400.
I do a lot of work at night, so I'll probably add that option as well. You are right your post did cost me some $$$ :laughing:
Birdman do you remember where you found the set of LEDs that fit?
   / Price check on Kubota M7060 HDC12 #19
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
John Deere 4020 Tractor (A50514)
John Deere 4020...
STORAGE FEES (A52141)
Informational Lot - Shipping (A52128)
Informational Lot...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
