You know it is cold on the farm when...
/ You know it is cold on the farm when... #41
Hard on those underneath too, we get the same thing but on extremely hot days, almighty crack and off comes a big limb from up high, the koalas do not enjoy the ride down either.
Koalas are nothing but a bunch of punks.
/ You know it is cold on the farm when... #42
They are vicious little sods except for the 'cuddly' ones you see on TV that have been brought up in captivity.
/ You know it is cold on the farm when... #44
Pure ethylene glycol freezes at about 8 degrees F. With the other additives that are in "antifreeze" it will freeze somewhere from about 0 F to -10F. Mixed properly with water the freezing point will go down to almost -49F I totally believe cans of antifreeze being frozen solid. NO BS.
I was a Chemist in my first life; and as I recall, mixing ethylene glycol with water, say 50/50 lowers the freezing point of both quite a bit. I never thought to check out his story, but I never doubted it. As a practical matter, I hate Winter and cold weather so I think more in terms of the Caribbean than I do of Alaska.
/ You know it is cold on the farm when... #45
...when you go to blow your nose and break off an icicle.
/ You know it is cold on the farm when... #46
Anti-freeze doesn't freeze in the Caribbean. It's used in drinks.
/ You know it is cold on the farm when... #47
When it gets really cold you can hear the nails popping out of the roof trusses.
Steel contracts at a greater rate than wood as it gets cold.
I have observed this phenomena in every newly built house that I know up here in cold Canada.
Generally occurs when the cold hits -30 or so,
/ You know it is cold on the farm when... #48
When you forget your handkerchief and this happens:
/ You know it is cold on the farm when... #49
When you leave "wool footprints" out on the front porch. And RUIN a good pair of wool socks.
/ You know it is cold on the farm when... #50
Winter in Amarillo Tx. 2009
My wife says we need to get indoor plumbing.
/ You know it is cold on the farm when... #52
I recall this same discussion several years ago; one of the group had been in the service in Alaska. He said it got so cold where he was, that antifreeze cans left outdoors would freeze up and burst. If there was a medal for the biggest BSer, he would have gotten it.
Working around Flagstaff and Williams Ariz. Had a new '61 Dodge truck. Went out around day light and engine sluggish to turn over so raised hood. top of Radiator was swelled and seeping out was a slush of antifreeze . took off the cap and could stick finger into the slush instead liquid.
also the city water system froze took several days to clear.
At Flagstaff went into a Penny's store purchased new pair of insulated work boots. stepping onto side walk felt the sole of the boots crack and returned to store traded for different brand.
returning home the house was so cold moved the children into living room/kitchen area. we all lived with in touch of the gas heater.
cattle froze standing in the open unprotected by the wind.
We worked with so many layers of clothing by time getting everything unbuttoned. better be inside a enclosed area. or endanger the exposed area (sticking tongue to metal pipe for example) consider the whole tail end frozen to commode seat.
ken
/ You know it is cold on the farm when... #53
When you see a chicken with a a capeon.
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61306)
2022 Greenworks...
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
