Starter keeps cranking
   / Starter keeps cranking #1
70jd400
Member
Fitzwilliam NH
JD 400 Industrial
I have a 1970 JD 400 industrial. A few days ago i tried to start it and it just kept cranking. I pulled the starter took it apart and cleaned it up. To day i put it back in and it did it again so i went out and got a new starter solenoid and put that on. Well guess what... It does the same thing turn the key it cranks let go of the key and it still cranks. What could be the issue? Could i have put the wires back on wrong?
   / Starter keeps cranking #2
ignition switch is the likely culprit
Ok thank you. I guess ill get a new switch and try that. Guess i wont be plowing with it tomorrow.
   / Starter keeps cranking #4
You can check it easy enough. Remove the exciter wire at the solenoid (the smallest one, probably 14 gauge or so) and connect a test light to the wire. When you hit the key, the test light should only stay lit as long as you hold the key in crank position. If it stays lit then your switch is confirmed bad.
In that case you could have somebody yank the wire off once you get the tractor started so you can plow snow until you can replace the switch.
   / Starter keeps cranking #5
It will surprise me if ign switch is at fault. Low battery voltage or arc spots can cause washer(outlined in red) inside solenoid to stick to stud heads(outlined in green). Did you disassemble solenoid cap & chec k for arc spots on outlined components.
There was on the old solenoid. So i bought a new one and same problem. I took the ignition switch out and with a multi meter checked from the battery lead on switch to the solenoid lead on switch while the key was in start position and it toned good. When i let go of the key as if it has started it toned good too.Starter Solenoid.jpg
   / Starter keeps cranking #7
What is "toned good" ? Lost me there... sorry
   / Starter keeps cranking #8
The OP's meter obviously has a tone for the continuity check.
It is a very handy function, and most quality meters have that feature.
   / Starter keeps cranking #9
Don't know if this applies. On the old John Deere 730 (24 volt starter) mine starting acting like this. You'd start it and the tap the starter/solenoid with a hammer to get it to disengage. About 6 weeks of this "little circus" and the starter/solenoid was done. Turned out starter was ok and had to put a solenoid on it. Then no more trouble.
   / Starter keeps cranking #10
That wasn't much of a surprise..
Yes. Sorry. I was checking the continuity on the switch. The switch checked out ok.
I have put a new solenoid on it and it still does it. I am leaning towards the batteries are junk. Not holding enough amps. I am gonna try new batteries this week when it warms up and the fuel filter and pump can de-jell.
   / Starter keeps cranking #13
Before you buy batteries, can you disconnect all the wiring off your starter but the battery cable, and then after blocking the wheels and double verifying that its in neutral jump from the starter battery post to the solenoid switch terminal to see if it behaves normally then.
   / Starter keeps cranking #14
I have witnessed where low battery voltage caused solenoid internal washer to stick to studs more especially on 24 volt starters.
A few days ago I tried to start it after charging the batteries and everything was good the solenoid acted as it should (start let go of key and starter disengages). I took a while to start because there was some jelling going on. Once it died I tried to start it again and the starter stayed on would not turn off until i disconnected the batteries.
Later on this week when it warms up above 30 and the lines de-jell i will try it again with a full charge on the original batteries and if that doesnt work than i will try jumping at the solenoid as stated in post #13.
   / Starter keeps cranking #16
You have a low voltage problem.
I had the same thing on my John Deere 350D and it took awhile to find too, so don't feel too bad. I always start with the easiest and the least expensive things to check first. Here is a short list...
1. Check to make sure the positive lead wire is not chaffed and shorting out on the chassis somewhere robbing your starter of voltage
2. Check batteries
3. Check negative battery terminals for contacts on chassis
4. If you have a spare battery cable, try attaching it from starter to chassis, sometimes a starter does not get a good ground through the chassis due to oil and paint, etc
5. But, you said the tractor is industrial. I wonder if it has a battery disconnect switch? If it does, that is most likely your culprit. That is NOT a knife switch, it has contacts that as you move the lever, it brings power upwards and into contacts. These arc out over time and cause low voltage problems. It took me awhile to find that issue on my tractor.
It is best to put the disconnect switch on the negative side of the batteries, but is not always easy to do. It does however prevent arcing inside the switch.
Ok. So i took the starter out and took it to a garage that my wife works at and one of the techs there bench tested it. He said the starter is fine and he be leaves that my problem is the spacer and the tip of the starter is no longer sitting in the grove witch is letting the gear over through the flywheel and the starter gear is becoming hung up and not retracting. So i have ordered the new spacer for $9. Just waiting on parts to come in. I ordered #'s 6,7,8
Ok. So I have received the parts for the starter and put them in. It starts up and the starter is acting normal and it seams that it is easier to start. Not a long slow crank. So maybe this was an issue for awhile and it just got worse.
Thank you everyone for all of your input.
   / Starter keeps cranking #19
Thanks for posting the follow up. Glad to hear you got it going!
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
electronic letter sign (A59228)
electronic letter...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2017 JOHN DEERE 470G LC EXCAVATOR (A60429)
2017 JOHN DEERE...
