2 speed tranny vs 3 speed. Is it really a big deal?
   / 2 speed tranny vs 3 speed. Is it really a big deal? #51
Member have posted saying their BX has no power on a hill... then find out they were in high range or had the 3pt engaged...
I have to be on flat to use the high range... 98% I am in Low.
Even the Deere 110 is seldom in High with 3 ranges due to the SF Steep terrain when roading it...
I use high gear moving around the driveway, that's about it. It really would be great if there was a mid range gear that split the 2.
   / 2 speed tranny vs 3 speed. Is it really a big deal? #52
Having never driven a Kubota 2 range all I can say is they must be very different from a JD 2 range based on the statements here. As I have noted I usually operate my 2320 in high range. Snowblowing I usually use low range but today I made a couple of passes on the driveway and then noticed I was running in high range (just forgot to shift it). Only reason I noticed was the wheels didn't spin as quickly when I backed into a snow bank. Mine has a wide band in each range.
Bottom line is that I think there is more to the comparisons than just 2 range/3 range.
   / 2 speed tranny vs 3 speed. Is it really a big deal? #53
You are right in saying there is more to it than just 2 or 3 range but sadly in most cases the 2 range is too much of a compromise.
My JD would probably be fine if I had no other tractor experience and only ever operated it.
   / 2 speed tranny vs 3 speed. Is it really a big deal? #54
thanks for all of your help everyone. Sounds like the majority say 3 speed. Now I've narrowed it down to Kubota L3901 and Kioti CK4010. I fear the B2650 just won't have enough to pull a large cutter up my hill. You all are super knowledgeable and I hope to return the favor once I make a decision.
In my view, the biggest issue with the B2650 is the fact that the PTO horsepower is still less than 20 hp.
   / 2 speed tranny vs 3 speed. Is it really a big deal? #55
With my BX I agree it doesn't take much of a hill before it sounds like its straining. Usually if I'm doing any kind of work, its in low, but that's also really slow, so if you get on flat ground, I just shift. It works, like someone else said, your just shifting more than if you had 3 speeds. Top speed is also really bad with a BX but that's more to do with the size of the tires. It would probably run 50mph if it was geared for it but you would die if you hit a small bump.
   / 2 speed tranny vs 3 speed. Is it really a big deal? #56
My DX 40 has a two speed hydro with hi and low in each range two speed works off the joystick or a fender switch I use it all the time I don't think I would be happy with a two speed in my tractor.
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A51248)
INGERSOLL RAND...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
John Deere Z970R (A50123)
John Deere Z970R...
