rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,654
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Hill High Guy,
You can always take a less conventional route that a fellow turned me on to with a B2650.
This assumes that you do not care about the mid mounted mower option and will use a 3-point finish mower instead.
You order your B2650 with the Kubota wheel spacers, and you also order it with a much wider set of tires that also allows for more added fuid weight. You see, the B3350 shows 2 R4 tire options, one being the same standard 12" wide R4 from the B2650, but the optional tire is a 15" wide R4 tire that is 3" taller (1.5" taller at the axle).
SNIPPED SOME OF THE QUOTE
Rock Crawler, that tire swap sounds great! Killer look, too. It should work mechanically as long as you or the dealer checked to make sure that the front to rear rolling circumference ratio remains within bounds. Otherwise the front to rear drivetrain stress will be too high in 4wd. That has to be checked, and it wouldn't hurt for us to double check their figures.
I believe that the technical dept. of both Titan and Goodyear will have the rolling circumference spec. available and will send it if you ask. Goodyear used to publish all their specs online, but I don't see them right now. Since you have some time right now it wouldn't hurt to calculate the stock ratio and compare it to the new one. The spec you need is the rolling or loaded circumference. Rolling circumference differs from a standard arithmatic circumference because rolling circumference takes the elasticity of the sidewall into account.
Luck, rScotty
