Plowing, Getting unstuck and groving tires.
   / Plowing, Getting unstuck and groving tires. #1
Kaje36
Member
NH
Yanmar 324
I recently put together a bit of a winter prep video with my tractor. I show how to grove tires, and 3 ways to get unstuck
Winter Prep - YouTube
   / Plowing, Getting unstuck and groving tires. #2
Can you tell us what grooving tool you ended up with?
I don’t have a BH so my “step 2” for getting unstuck is to position the blade flat on the ground (FEL up and curl down) and ease the FEL controls (typically curl up) to move the tractor.
   / Plowing, Getting unstuck and groving tires. #3
   / Plowing, Getting unstuck and groving tires. #4
Great video!
Did I understand that correctly, The diff lock is integrated with the break peddle?
   / Plowing, Getting unstuck and groving tires. #5
Great video!
Sounds like it on that tractor:confused3:
Great video!
Yup, on the Yanmar SA series its part of the brake pedal!
   / Plowing, Getting unstuck and groving tires. #8
How much to groove my tires
   / Plowing, Getting unstuck and groving tires. #9
Like the tool for grooving...thanks for sharing. :thumbsup:
   / Plowing, Getting unstuck and groving tires. #10
wow that would be hard to get used to... it was hard enough for me to get used to the brake on the left side on my new tractor. Use to the clutch on the left and break and gas on the right.
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
30KW GENERATOR (A58214)
30KW GENERATOR...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
UNUSED FUTURE MCW39 39" HYD MINI COMPACTOR WHEEL (A58376)
UNUSED FUTURE...
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
2014 Case 601D Directional Drill (A57453)
2014 Case 601D...
