Plowing, Getting unstuck and groving tires.
   / Plowing, Getting unstuck and groving tires.
wow that would be hard to get used to... it was hard enough for me to get used to the break on the left side on my new tractor. Use to the clutch on the left and break and gas on the right.
its not too bad, I don't often need to use the diff lock, the standard 4-wheel drive gets me out of almost anything I get into. I only used it about 3-4 times a year,.. and mostly when I am being dumb, lol I didn't really need it at all when driving in the deep snow.
   / Plowing, Getting unstuck and groving tires. #12
That's true, with the new tractor I've only had to use it when pushing lots of snow or stuck in the mud. Seems like I used it all the time with my Mitsubishi that had the tall skinny AG tires.
   / Plowing, Getting unstuck and groving tires. #13
Can you tell us what grooving tool you ended up with?
I don稚 have a BH so my 都tep 2 for getting unstuck is to position the blade flat on the ground (FEL up and curl down) and ease the FEL controls (typically curl up) to move the tractor.
I have one if someone wants to borrow it.
BOMAG BMP 8500 TRENCH COMPACTOR (A52709)
BOMAG BMP 8500...
9 Fisher Snow Plow With Minute Mount (A55272)
9 Fisher Snow Plow...
SKIDDED FRAC TANK (A58216)
SKIDDED FRAC TANK...
Mower King SSRC72 72" Brush Cutter (A57149)
Mower King SSRC72...
1991 MACK CH613 DUMP TRUCK (A58214)
1991 MACK CH613...
1990 Ford Off Road Water Truck (A57148)
1990 Ford Off Road...
