Plowing 1/2 mile driveway with a UTV. Should it be done?
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #1
MGH PA
Gold Member
Northcentral, PA
2005 Gravely 148Z 48" ZTR
We are going to building in the next year or so and out property is going to have ~1/2 mile driveway to the home. The elevation gain is minimal (~30 ft of variance across the entire length), and it is90% open field, with the last 10% leading to the house wooded. My dads property borders us, and he has a JD 990 and a plow truck. I have a Rubicon with a warn plow that I use at my current place (small driveway). We had talked about selling the rubicon and buying a UTV and plow setup so we have a more capable machine for the larger acreage (can take the family with me, use it for hunting, chores, etc.).
I know most would recommend a plow truck for this size driveway, but I知 wondering how a UTV might fare? We don’t get a lot of large snows in our area, but when we do, I can always fall back on my dads truck if need be (or his tractor with his FEL if I need to move piles). I just want something that can be both recreational as well as useful, and I don’t need to buy a cabbed tractor at the moment (as some might suggest) since I have access to tractor for tractor duties. I own a new Tundra, but don’t want to plow with it (too new, don’twant to prematurely wear things out, etc.).
Thoughts? If this is a yes, should I be looking at more work oriented brands such as the Gators, Bobcats, and RTVs? I really like the Honda Pioneer 700-4 for its versatility in seating/cargo room, but unsure of how it would handle the work I want to throw at it.
Btw, the property is 150 acres, so it will be used quite frequently for other duties.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #2
IMO, for what you are going to spend on a UTV with a plow I'd look into buying a tractor with loader and a QA plow blade. You'll have more uses for a tractor on 150 acres.
I guess it depends how often and how much snow you get and since your Dad borders you and you can get his plow truck and tractor any time then a new UTV with plow may be OK.
Sorry, I'm not much help but I'd still vote for a tractor..
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #3
You are moving to 150 acres, half mile driveway and building a house. You want a UTV for recreation - that's just fine. You will soon learn that to develop, improve and maintain the property and driveway - you a going to need a 50 to 75 hp - 4WD tractor with FEL & bucket and a heavy duty rear blade.
As far as being much help with the development, improvement and maintenance jobs - the UTV is going to be a lot like T*TS on bacon. Fun to play with but little help.
If you are serious about your new property - you definitely need a good tractor.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #4
There is a pretty good web-site devoted to the Honda UTV (hondasxs.com) and the topic of snow-plowing is there. I'm sure all the major brands have similar forums. Btw, "sxs" ("side by side") is the standard lingo for UTV's. I own the 700 2 seat model and apart from one issue (the maintenance schedule and the difficulty in performing such...that may not be unique to Honda) I'm sure the machine could handle it...it is a well-built beast.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #5
I dunno...for years I did my 300' long driveway with a plow mounted to my CubCadet 1250...wasn't a quick thing but at the time it was all I could afford (and the cold didn't bother me).
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #6
I plow a half mile logging road with my bulldozer with a 8 foot and 6 way blade, and I think it is slow and often say, "there has got to be a better way". In all honesty from someone who does it, I would think something warm and dry would be the answer.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #7
Assuming gravel driveway?
A tractor will be in my future but not in the budget right now. I can get a plow/700-4 for around 12-13k (leftover model). Can't touch a cabbed tractor for anything close to that.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #9
Quite the analogy. :laughing: never gonna look at bacon the same way.
   / Plowing 1/2 mile driveway with a UTV. Should it be done? #10
Buy an old plow truck. You can probably get one, ready to plow, for under $3000...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2013 DODGE CHARGER SEDAN (A54607)
2013 DODGE CHARGER...
