Worked on the Massey GC today
   / Worked on the Massey GC today #11
If you had turf tires, and enough weight on the back, you would be even more surprised.
Probably right but I do too much dirt work in tacky soil for turfs.
First time starting the tractor today using the block heater and silicone pad heater, plugged them in for about 3 hrs, it was 14 degrees. about 30 seconds on the glow plugs, the GC started pretty easy. I let it warm up for awhile, then I brought about 8 or 9 buckets of firewood in.
Glad I did both heaters and switched to synthetic oil.
   / Worked on the Massey GC today #13
3 hours may be okay for the block heater. 15 seconds of glow plugs will probably be enough, because it's not really a cold start, with the heater.
However, that silicone pad heater isn't doing much in 3 hours.
It takes a long time to warm that much oil.
I plug mine in a few days before the forecast suggests I'll need it.
If you use your tractor a lot, I would just leave the trans heater plugged in when it's cold.
I don't use the GC that much in the winter, maybe twice a month.
Tractor sits in a TSC garage in a box.
If the outside temps are mid teens low 20's...
5 to 6 hrs for the Block heater?
2 to 3 days for the Pad heater?
   / Worked on the Massey GC today #15
I can't say for sure on the block heater, I don't have one. But, I believe most people have said 3 hours is enough?
Three days on the Pad heater would probably be the minimum. Mine sometimes runs for a week or more, and parts of the housing are still cold.
I don't know your wattage. But, mine is only 140 watts. That's only enough to keep the oil from getting really cold at those temps.
It's more of an insurance policy, than a work around for the extended warm up periods.
I would still allow a while running at high idle.
Thanks for the tips.
   / Worked on the Massey GC today #17
FWIW: The M-F block heater (you know, the pricey one!) is 400 Watts. I'll often leave mine on for several hours.
   / Worked on the Massey GC today #18
One time I left it plugged in for 8 hours and it was hoooooot. I think I heard the water boiling-is that a bad thing?
   / Worked on the Massey GC today #19
I guess it's possible it's boiling in a very small amount, right at the heater, but the heat is dissipating as you move away from that area.
If you boiled all your coolant, you would build very high pressures, and the radiator cap would let that pressure escape, leaving you low on coolant.
I don't know if it can get too hot. My guess is no. Especially, when it's very cold.
I am sure someone has left theirs plugged in a lot longer than 8 hours. And, there does not seem to be any dire warnings here.
   / Worked on the Massey GC today #20
Yeah I was worried it might cook something like a gasket. It was just coming from the area of the block heater. Now I just plug it in 1-2 hours before using it just in case.
2017 Mercedes Benz GLA SUV (A55758)
2017 Mercedes Benz...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
Case-IH 370 Steiger (A53314)
Case-IH 370...
