Manual hand pump for wells
   / Manual hand pump for wells #1
widefat
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
What's your experience with manual hand pumps for wells? 100-150 feet?
I am looking for something for extended power outages -
TIA~!
   / Manual hand pump for wells #2
How much water are you looking for?
I have a drilled well (250' ish feet deep), and after 1 day of no water use in the spring, the water level was less then 50' from the surface.
The problem is there is no pump that will suck the water up 100'... the pump mechanism needs to be at the bottom. there are some manual pumps out there that place the mechanism down low, but they are very expensive.
I've thought about the "extended outage" scenario, and the best solution I came up with was to use rain barrels, and a nearby pond for water to flush toilets. keep a pack of water bottles for drinking (12 Liters) use the water in my hot water tank for cooking.
AND if all that wasn't enough... I'd like to build a small water bucket out of 2" or 3" pipe fittings that I can lower down into my drilled well on a long length of para cord/ poly rope. just to pull clean drinking water.
   / Manual hand pump for wells #3
Yes they work down about 100-125’ feet. You take a garden hose from the hand pump to a hose bib on the hose “circuit” and can “backfeed” the entire house. You shower- she pumps and vis versa. They drop in next to the existing piping and can typically just stay there without issue of freezing etc.
I saw one that sealed against the inner wall of the pvc pipe- I didn’t think that was the best idea but the company had a great reputation so who knows what the best style is.
   / Manual hand pump for wells #6
The actual pump is set at below the water level. How deep depends on how strong you are.
   / Manual hand pump for wells #7
I bought the EZ Well Hand Pump; I got the deepest model, it was $240
and another $60 for piping.
You have to buy your own pipe; it takes 1" thin wall pvc and 1/2" regular pvc.
My regular pump is down 100'; water level is down 63', so I put the hand
pump down 80'. It takes 10 strokes to bring the water to the top.
Then it takes 10 strokes for a gallon of water.
You have to glue the 10' sections of pipe together as you are putting them in the well.
But the one I got appears to have a defect.
After you finish pumping, it drains the inner pipe rather rapidly (within 10 minutes).
Then it takes another 10 strokes to get the water back to the top.
Apparently, the check valve on the end of the inner pipe is not holding completely.
I contacted the company about it and they admitted that it wasn't working as
it should, but they refused to replace it, say that as long as it was pumping water,
that it was doing it's job.
I would not have bought this pump if I had realized that to pull the regular
pump, I would have to pull the hand pump first, thus cutting each 10'
section into to remove it.
I had forgot that the regular pump has a boot just above it to prevent the pump
from banging against the well bore when it starts and stops.
This boot would not clear the hand pump piping, so the hand pump would
have to be pulled first, which defeats the ability to manually pump water
if the regular pump must be pulled for repair or replacement.
But for loss of electric power, it would supply water from the well.
   / Manual hand pump for wells #9
TIA~!
My backup well is a separate 2" galvanized driven well (in sand).
The well depth is 40 ft., and it has a permanently mounted deep well rod type pump on top.
Works great.
The well and pump have been in place for 85+ years. It has occasionally been repaired, and I pump it (by hand) a few times each year, just to make sure everything still works.
Pitcher pumps will only work for depths up to about 20 feet.
   / Manual hand pump for wells #10
For the stated purpose it seems like a generator would be a better choice. Checking Amazon it seems like 240v units start around $250. Plus you can run everything else in the house.
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Electric Mobility Scooter (A51694)
Electric Mobility...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
FAKE (A52472)
FAKE (A52472)
