Saw won't stay running......Stihl MS290
   / Saw won't stay running......Stihl MS290 #1
Ville Platte, LA
John Deere 870
Hi everyone, I have a Stihl MS290, it's maybe 5-6 years old and has not seen a lot of use.
Lately it's been giving me an issue that has me stumped. First off, I have cleaned the carb out completely and have adjusted the carb as well as I can, so a clean carb is not the issue, I think.
Like a typical 290, it will take a few pulls to start. It will run for about 5 minutes, and will cut well, but then it will start choking and die.
After that, it will crank up again but when I put a load in it, it sputters and dies. I have also cleaned out the fuel pickup with clean gas and compressed air.
Can anyone help?
LC
   / Saw won't stay running......Stihl MS290 #2
Chainsaws used infrequently should be stored with all fuel run out.
Did you dump the old fuel and replace with fresh fuel?
I would install a new spark plug next.
Fuel is fresh, spark plug was clean, I am pretty sure it was giving good spark. If it was bad, I don't think it would run with power at all.
   / Saw won't stay running......Stihl MS290 #5
If that model saw has an impulse line it would be my first thought after the fuel line itself...
   / Saw won't stay running......Stihl MS290 #7
When it starts to run rough, does pulling the choke out a little bit help it run better?
   / Saw won't stay running......Stihl MS290 #9
When it quits, open the fuel cap and close it. If it starts back up, it's the vent.
   / Saw won't stay running......Stihl MS290 #10
I worked on a neighbor's 2 cycle weedeater once and the screws that held the two halves of the two halves of the crankcase had loosened up a little, so it would run OK with the choke on (it was sucking in air through the crack between the case halves and that would lean out the mixture). Once I tightened up the crank case bolts, it ran pretty well again.
Stateline SJ-100 3 Phase Generator (A57148)
Stateline SJ-100 3...
2008 Ford F450 Lariat Pick Up (A55272)
2008 Ford F450...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
