Saw won't stay running......Stihl MS290
   / Saw won't stay running......Stihl MS290 #1
Ville Platte, LA
John Deere 870
Hi everyone, I have a Stihl MS290, it's maybe 5-6 years old and has not seen a lot of use.
Lately it's been giving me an issue that has me stumped. First off, I have cleaned the carb out completely and have adjusted the carb as well as I can, so a clean carb is not the issue, I think.
Like a typical 290, it will take a few pulls to start. It will run for about 5 minutes, and will cut well, but then it will start choking and die.
After that, it will crank up again but when I put a load in it, it sputters and dies. I have also cleaned out the fuel pickup with clean gas and compressed air.
Can anyone help?
LC
   / Saw won't stay running......Stihl MS290 #2
Chainsaws used infrequently should be stored with all fuel run out.
Did you dump the old fuel and replace with fresh fuel?
I would install a new spark plug next.
Fuel is fresh, spark plug was clean, I am pretty sure it was giving good spark. If it was bad, I don't think it would run with power at all.
   / Saw won't stay running......Stihl MS290 #5
If that model saw has an impulse line it would be my first thought after the fuel line itself...
   / Saw won't stay running......Stihl MS290 #7
When it starts to run rough, does pulling the choke out a little bit help it run better?
   / Saw won't stay running......Stihl MS290 #9
When it quits, open the fuel cap and close it. If it starts back up, it's the vent.
   / Saw won't stay running......Stihl MS290 #10
I worked on a neighbor's 2 cycle weedeater once and the screws that held the two halves of the two halves of the crankcase had loosened up a little, so it would run OK with the choke on (it was sucking in air through the crack between the case halves and that would lean out the mixture). Once I tightened up the crank case bolts, it ran pretty well again.
John Deere 1025R (A53317)
John Deere 1025R...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
Utility Cart (A59231)
Single Cedar Glider (A57454)
Single Cedar...
