Batteries left sitting on concrete?
   / Batteries left sitting on concrete? #1
bcp
Super Star Member
SW WA
Kubota BX2360
I'll bet most of us have heard that we shouldn't. Here's some information I found while looking for something else.
ASK THE EXPERTS: Batteries on Concrete | Home Power Magazine
"Many people have the impression that when batteries sit on concrete, energy "leaks out" or they are ruined. The short answer is that letting modern batteries sit on concrete does not harm or discharge them in any way. However, this legend is historically based in fact. "
Another link:
Yuasa Batteries - FAQ's
Bruce
   / Batteries left sitting on concrete? #2
Huh - interesting. I think I've heard that story somewhere. No problem with that here - I have no concrete floors.
   / Batteries left sitting on concrete? #3
This used to be a reliable family argument when I was small. My mother's brothers thought batteries discharged on concrete, my father's brothers thought they were being stupid.
   / Batteries left sitting on concrete? #4
I lost too many batteries sitting on cement to fall for that lie. All the experts ever say is old rubber based batteries (I've never seen one) would drain but modern plastic ones are not at risk. Yet I have had it happen to me. Those same experts say that you don't need to let your car engine warm up for more than a few seconds to get oil flowing when cold out. The problem is none of those experts will come over and pay for a replacement engine or battery. Maybe in the south it's different but up here in the cold months things left on cement get cooled down and attract moisture. In that moisture will be any minerals that were in the cement. A simple test is to place a piece of steel on a cement floor and one on a board on the cement floor. The steel on the floor will rusted like crazy in the spring.
I would guess a sealed battery is probably a lot more resistant to being damaged. Between the cement, moisture, sulfuric acid, lead, and anything else that has deposited itself on the outside of the battery you have a whole chemistry set. The lead will oxidize. The cement will create calcium carbonate (a base). I can see multiple ways a battery could be drained. The moisture could create an electrical path between the terminals and the calcium carbonate could react with the sulfuric acid and turn the electrolyte in the battery into salt water (on a vented battery) seem like the two most likely off the top of my head.
   / Batteries left sitting on concrete? #5
The solution for you Al - don't set your batteries on concrete.
   / Batteries left sitting on concrete? #6
I've had 2 battery's sitting on the concrete floor in my shop for the last 6 mons. checked them just yesterday to see if they needed topping up 1 had 12.68 volts the other 13.4 guess I have good battery's or a good floor. I had them both on a battery minder last June for a wk. each when I took them out of my fork lift.
   / Batteries left sitting on concrete? #7
Never had a battery go dead sitting on a concrete floor but have seen many go dead from parasitic drain across the top of the battery. Battery looked clean but I would get a voltage reading from the negative (or positive) terminal and anywhere on top of the battery. A good cleaning with baking soda and water cleaned it off and no more leakage.
   / Batteries left sitting on concrete? #8
I'm old........My dad taught me not to set batteries on concrete. I still do it, maybe out of habit or maybe out of respect for my dad.
   / Batteries left sitting on concrete? #9
I set my batteries on a block of wood also, I've seen them sweating when on the concrete and they don't seem to on wood.
   / Batteries left sitting on concrete? #10
I first heard that story almost 50 years ago. No one could tell me why, but several people swore it was true. Until I bought my current place I never had any concrete floors either so it was a moot point. I will say that in spite of my skepticism, I do set batteries on a piece of wood "just in case".
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
