OP
mtnwings
- Joined
- Nov 18, 2017
- Messages
- 70
- Location
- Ellenville, NY
- Tractor
- ford 1910 4x4 loader, MF 35, MF 60H backhoe
Hello, The rod button is an override, there is a big 3 x6 inch sticker on the window that tells what it is and why and when to use it. It is located next to the ignition switch and the kill switch (fuel stop) . Did yours have hydro static drive? This one has a long shiftier on the right that puts the machine in the speed range you want, 1st, 2nd, third ect, you select the range you want, be it driving to a work area or loading dirt, climbing a hill or what ever and there is a lever next to the steering wheel that is used to go forward and reverse, no clutch. The lever that tells the transmission to change from forward to reverse is electronic operates two different solenoids, they both are hot all the time. GLyford explained that very well to me, I did not know much about this. It is in the 20"s and snowing, it has been snowing for many days so getting out to test all this will need to wait till warmer weather.
