PTO Generator on 1920 Diesel,,,,
   / PTO Generator on 1920 Diesel,,,, #12
Those who add up watts will be bitten in the backside with VAR’s and wonder why the 4800 watt load keeps tripping the breaker on the 5000 watt generator .
correct.. you can't simply add them up, but they are still inter-related.
Most people don't understand motor start loads either, and why some air handler / compressor systems have a delay built in to stagger starting loads.
   / PTO Generator on 1920 Diesel,,,, #13
Fuel consumption depends on generator load About 1.5 TO 2.5 GPH.
   / PTO Generator on 1920 Diesel,,,, #14
I would hope that your little Ford wouldn't use that much fuel on a small generator, it will vary with the load but you should be under a gallon/hour. My generator is a 25 KW but under normal use I average about a gallon / hour with either 80 HP or 65 HP on it, I do run the big one in the economy pto speed.
   / PTO Generator on 1920 Diesel,,,, #15
Bottom line, fuel usage is based on generator electrical load.. can't dodge physics. there is a certain amount of energy in the fuel, and there is a physical conversion from hp to wattage.
No free meals.
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2012 INTERNATIONAL...
Case Titan 3530 (A56435)
Case Titan 3530...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2017 Chevrolet Silverado 3500 Ambulance (A55973)
2017 Chevrolet...
1288 (A58374)
1288 (A58374)
2017 DODGE RAM 3500 DUALLY (A58214)
2017 DODGE RAM...
