Ford 5610 rear stabilizer bar help
   / Ford 5610 rear stabilizer bar help
Can you send me a pic of them installed on your tractor? Just can’t picture how they hook up. Thanks
   / Ford 5610 rear stabilizer bar help #12
You bet. I'm on my phone. In mornin I'll get on shop computer an attach what I can find. Remind me if I forget...
I’m a little gun shy as the first set I ordered for my 4610 would not work. If I remember correctly the bolt/pin diameter was too small where it connects to the lift arms. To make it work I was going to need to switch lift arms or drill existing ones out but was worried that might compromise the arm strength.
   / Ford 5610 rear stabilizer bar help #14
stibalizerchain runs from the outside (not inside) to the arms and sould have its anckerpoint inline with the lowerpoint attach to the tractor. Yours will brake when impl is atached.
   / Ford 5610 rear stabilizer bar help #15
   / Ford 5610 rear stabilizer bar help #16
I've got hundreds of pics of my tractor but can only find one that include the stabilizers. I'm going to the farm where it's parked today. I'll get better pics.
My stabilizers came with brackets that U-bolted to the axle housing outside the fender/ROPs brackets. Then bolted to the lift arms. I don't recall having to drill my arms.
Here's a pic that barely shows the axle end.
   / Ford 5610 rear stabilizer bar help #19
Here's a couple pics of mine.
   / Ford 5610 rear stabilizer bar help #20
remove that chain
When I bought my tractor that's the exact setup it had. Installed at the factory.
I switched so I had better adjustability.
2021 Jeep Wrangler 4x4 SUV (A51694)
2021 Jeep Wrangler...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
Towable Orchard Sprayer (A51691)
Towable Orchard...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2013 Ford F-650 Flatbed Truck (A51691)
2013 Ford F-650...
