Dual 195 loader
   / Dual 195 loader
   / Dual 195 loader #12
A quick Google search found all of this. Looks like there's a manual there that might help you. Also for future reference, you might list that your FEL is a Woods brand. Very popular brand of equipment and knowing that changes responder's direction.
Welcome to TBN.
Dual is the brand of the loader it is marketed by Woods.
About Us | Miller Loader
Woods Equipment acquired Du-Al in 1993. Du-Al loaders were manufactured in Sioux Falls, SD.
   / Dual 195 loader #14
This is where the filter should be.
What you circled in red is the starter on our 1966 Ford 3000. Its hydraulic filter is inside under the lift arms plate but 1968 was a major model change year.
That is one good looking FEL. We are in the process of getting an old Ford one arm 711 FEL mounted on our 1966 3000 diesel for use where the JD backhoe is too big.
   / Dual 195 loader
Love the tractor, still having issues with power steering but going to get some time to look into a new pump soon for that as well. Loader is in good shape, one long hose going to the front pump needs to be replaced. I notice it jumping around as I lift the bucket. Hopefully a trip to the dealer tomorrow for some info will help me some.
   / Dual 195 loader #17
It appears to me this FEL does in fact use it's own fluid source and reservoir. No connection to the tractor. It may not have a filter beyond a screen one in the tank? D2Cat's link might shed some light??
The pump hose movement would be caused by pressure changes, mostly likely from air in the system.
Curious to find the solution to your problem. Hoping it's something simple and cheap. :)
   / Dual 195 loader #18
I wouldn’t be surprised if there is no filtration at all. I think it likely needs to be flushed out really well. The groaning could be a sign of blockage.
Does the groaning occur all the time or just when lifting or curling?
   / Dual 195 loader #19
Might call these folks. Woods equipment Co. Sioux Falls, SD 605-336-3860. They should know the answer or direct you to someone who does.
   / Dual 195 loader #20
Yeah, that was my thought when mentioning Woods earlier.
2013 HAMM GRW280I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAMM...
2005 Peterbilt 357 T/A A-Frame Gin Pole Truck (A60460)
2005 Peterbilt 357...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
