Dealing with bulk / 5 gallon bucket of oil
   / Dealing with bulk / 5 gallon bucket of oil #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I just added another hungry mouth to the stable (a 1999 Dodge Cummings 2500) Between my tractor, My kubota RTV, and now this, I need to step away from Mobile One and go toward a more economical solution.
So how do you all deal with 5 gallon buckets of oil when putting it into a machine. I am struggling with how to make sure I don't over fill the machine. Any decent pumps that are not bank breaking or any other ideas on how you guys handle it.
   / Dealing with bulk / 5 gallon bucket of oil #2
Fill Rite used to have a nice little oi bucket pump that was abs and would screw onto the flex spout and had a short section of clear tubing on it Coastal Farm or Wilco used to have them and they were in the $30 range.
Harbor Freight has a slightly upgraded version with a metal pump barrel pretty cheap.
5 Gallon Oil Pump
David
   / Dealing with bulk / 5 gallon bucket of oil #3
My tractor takes 16+ gallons of hydraulic oil per change. I've got a funnel with a looooong flex neck. Brings the body of the funnel up where its easy to pour from the five gallon bucket. I "hang" the funnel off the back of the tractor seat with a chunk of wire. Funnel held in place - pull out the spout from the first five gallon pail and pour away. Three five's plus a one gallon jug - check with the dip stick and add from a one quart jug as needed.
Its gotta be easier for you to do something like this than it is for me - I'm 76 and have no problems.
   / Dealing with bulk / 5 gallon bucket of oil #5
I have not noticed much price difference in 1 gallon vs 5 gallon jugs. I would just buy 1 gallon jugs for easier use. They often come in cardboard boxes of three jugs which are easy to transport.
   / Dealing with bulk / 5 gallon bucket of oil #6
^This. I noticed not long ago at Walmart that their Shell Rotella T-4 15W40 was selling for $12.78 per gallon. There were 5-gallon buckets of the same oil right beside it -but when I divided the price by 5 it worked out to nearly $2 a gallon more than buying the 1 gallon jugs.
   / Dealing with bulk / 5 gallon bucket of oil #7
5 Gallon Oil Pump
David
I had one of those, they are junk, lasted for on bucket.
Ron
   / Dealing with bulk / 5 gallon bucket of oil #10
If you have the space, go with a 55 gallon drum and one of these and a tank pump. They are also handy pouring into from a 5 gal. I put a large plastic bag over it in between use's. The oil attracts dust.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
Utility Trailer (A52377)
Utility Trailer...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
