Forestry mulcher and no external hydro cooler?
   / Forestry mulcher and no external hydro cooler? #1
raptorterry
Middle of the field
RTV-X1140 L60 Grand
Hi guys. I have a T650 with standard flow hydraulics. I am either going to get a newer/bigger machine or setting my machine up for a forestry head made to operate at standard flow. If I set my machine up will l be smart to install a external hdraulic cooler even thou my machine is standard flow? I would definately install lexan "glass".
The reason I ask is that I see quite a few high flow skid steers for sale without hydraulic coolers and in the ads I see they are selling these machines with large forestry heads.
   / Forestry mulcher and no external hydro cooler? #2
Bobcats forestry cutter used on a large frame high flow SSL does not need a external hyd cooler. Cutter is a "Smart Attachment". Software controls the cooling fan.:thumbsup:
Just so my little mind understands, the Bobcat forestry cutter is the smart one? If I buy Fecon or any other brand it won't control the fan thru software?
BTW, thank you for your reply
   / Forestry mulcher and no external hydro cooler? #5
Correct. Bobcats forestry cutter is a smart attachment. It has a controller that talks to the SSL controller. The SSL recognizes the cutter when attached and changes the fan parameters. Could not tell you if other brands will work.:thumbsup:
Okay. Thank you. I gives me a starting point. I haven't looked at the Bobcat cutter but I know if it has the Bobcat name it's a good machine.
Last question. Do you know if Bobcat makes a forestry cutter for a standard flow machine and would it be worth getting? Or should I get a high flow machine to accommodate a bigger head?
   / Forestry mulcher and no external hydro cooler? #8
No. No standard flow cutter. Go with the high flow set up if you can afford it. You won't regret it.:)
   / Forestry mulcher and no external hydro cooler? #10
What is the flow & pressure of your auxiliary hydraulics on the T650.
Suspect it would severely limit the HP available to run a mulched head
For reference 20 GPM @ 3000 PSI is 30 Hp input power
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
