I'm embarrassed to say I just noticed the same thing. There are 4 hoses coming to each cylinder and I just didn't think about it, duh. This makes the transfer faster because there are only 5 large double acting cylinders, 4 of them are on the outriggers.Just noticed there are two single acting cylinders on your lift you could collapse these fully before the fluid change and that would remove majority of old fluid from this portion of the circuit
It's 12v, it uses four 6v golf cart batteries connected series/parallel to produce 12v and about 750A. That's a good point, it would be easier to just use the extra 12v car battery I have to make the controls come alive.Do you know if the coils are 12 or 24 VDC? If 12 you only need one battery. The extra batteries are for the DC power unit since they are amperage hogs.
I wish. When I first bought the thing I assumed the engine would charge the batteries, but that didn't seem to be happening. So I got a copy of the schematic and couldn't see anything but the battery charger. I called the company, they said the only source of charging is the battery charger. So every night I have to plug the thing in. Even if they had added a small extra 12v battery for the controls with a small alternator to keep it charged, that would at least allow the thing to stay out in the field without having to come home for charging. It can't be a weight issue, this thing is built like a locomotive. It must just be the extra cost makes them less competitive.Suspect the gas engine has an alternator to the battery charged also.
