22 Ton log splitter "issues"
/ 22 Ton log splitter "issues" #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
We bought a Husky 22 ton log splitter with a briggs 6.75 tq motor on it several years ago at TSC. When I bought it they sold it for ス price since someone bought it, took it home and it wouldn't run right and brought it back. It went to a small engine shop and was "fixed."
I didn't use it right away (middle of summer) and when I went to use it I noticed it ran poorly. Always surging and hard to start. Had to keep hitting the primer bulb over and over to keep it running until it was warm and even then never ran smooth. Figure I would take it in under warranty but then we couldn't locate the receipt (later found it was used as a book mark -oops)
Well I lived with it for another year and am getting tired of messing with it. Threw a new carb on it, new primer bulb, plug, etc. Checked all the lines, new gaskets, etc. Still did the exact same thing.
Wife said, go get a new engine and be done with it as it is not worth the time.
Harbor Freight has the Predator motors and the one is a direct replacement. (Had one of their motors as a replacement on a chipper and another one on my plate compactor and they both work great!) Stopped today and bought it ($120) and put it on this evening. No issues and was done in an hour. Went and started it and it started surging....
Have to VERY slowly bring the RPMs up so it won't stall and even when running full bore it surges and seems to hunt. If the the wedge hits the stop going forward it stalls it out.
What does this mean? I am thinking I have a hydraulic issue maybe? Or did I just get a bad motor (seems like 1 in a million to have similar issues as the one I took off)
Any ideas how I can test things?
/ 22 Ton log splitter "issues" #2
Something in your pump/valve is not opening/closing right.--could be check valve sticking, relief valve set wrong. thanks; sonny580
Thanks - I am pretty dumb on this one - any idea how to check it (or find it)
/ 22 Ton log splitter "issues" #4
I had a 28 ton Didier splitter about 30 years ago. After about three years it started doing same as yours. It was the needle and float in the carb. Not opening correctly - for whatever reason. Replaced and it worked great.
/ 22 Ton log splitter "issues" #5
Surging is almost always a result of fuel starvation. It usually happens because of debris or some sort of buildup of junk in the main jet in the carb. Does your engine have adjustment screws? If so, open them up about 1/8 turn and try again. If not, you need to have the carb cleaned, being sure to run a small dia. wire through every fuel hole you can find, as part of the cleaning process.
/ 22 Ton log splitter "issues" #6
Did you run the new motor before installing it? If these are indeed hydraulic issues as suggested by Sonny, you could try loosening up and sliding back the coupler halves so they no longer mesh and you can remove the rubber spider, snug down the set screws so the coupler halves stay put on their shafts, then start and run the motor so that it's no longer turning the pump and hydraulics. You won't be able to put a load on the motor, but if it runs OK at all RPMs then it would seem to confirm that the problem is on the hydraulic side. Maybe the filter is clogged, maybe pump is bad, maybe there is a blockage, etc.... If the engine struggles/hunts even when the valve is centered, then to me that suggests filter, pump, blockage in lines.
/ 22 Ton log splitter "issues" #7
Also, since these units are assembled at the store, double check that the hydraulic lines are connected to the right places and in the right order. I have seen some pretty sloppy assembly work done at these big box stores.
Thanks - I did not run test the engine before installing but can separate the coupler fairly easily. Seeing the motor is brand new and I put new gas in the tank I would be surprised if the carb was clogged. Since it is doing the exact same thing as the old engine made me start thinking something in the hydro system somewhere, just not sure where.
I am going to try and separate the motor/hydro tonight if I have time and will report my results....
/ 22 Ton log splitter "issues" #9
Same problem with two different engines means the problem is not with the engines. I would remove the fuel line and install a new line going to a clean source of fuel. Maybe a funnel with a fuel line and see if that solves the problem.
Thanks Eddie - Sorry should have mentioned that each motor had its own tank/fuel system. (Totally self contained)
When I pull the motor should i be able to turn the pump by hand?
/ 22 Ton log splitter "issues" #11
What about your fuel source? Same gas can? Same Gas Station? How much ethynal?
Went and bought fuel yesterday from Sheetz so I had brand new gas and (never thought of it) but did use a different can.
ok, here is a thought. It seem to idle ok, but soon as RPMs are added the issues start. I was reading it is a two stage hydro pump - could it be something with "stage two" when the RPMs go up?
Had to help the parents tonight so never got to pull the motor - looks like that will have to be put off to next weekend... Ugh
THANKS for the ideas and help
/ 22 Ton log splitter "issues" #13
It could be something in the pump restricting the flow!--never did like 2-stage pumps, and I only had 1 for a couple days on my homemade splitter!--You guessed it!! --day 3 it had an old 17 gpm 1-stage pump off an old combine installed in place of 2- stage!! LOL!!!! thanks; sonny580
/ 22 Ton log splitter "issues" #14
Water in the gas. Only takes a drop sitting on the bottom of the well where the main jet sucks from. The drop sits close below the jet and only sucks up into the jet at high throttle. If your new engine has a carb with a plate choke you can probably suck the water on through by revving the engine high and closing the choke momentarily. If the situation improves thats it.
... Might want to get a Mr Funnel for the future. Filters out debris and water.
Pulled the motor off and it seems to run fine - smooth and without any issues.
This is leading me towards the something else, maybe the pump, is the problem?
The pump does turn easily by hand but of course that is at a very very very low RPM.
I have a new filter and just replaced it, the hydro oil appears clean.
I will remount the engine and give it another run in a little bit.
/ 22 Ton log splitter "issues" #16
The 2 stage pumps are kinda complicated and if 1 part doesn't shift right or complete they won't work. Could even be a small sliver from manufacturing process jammed in an internal valve. thanks; sonny580
Changed the oil.
Changed the filter
Pulled all the lines off and flushed them.
Seems to run good now without issue?
The original oil had a little milkiness (had less then 8 hrs use total) to it and I am not sure what the assembler used as ISO46 was recommend and the old oil appeared different.
/ 22 Ton log splitter "issues" #18
Changed the oil.
Changed the filter
Nice buddy, so you got it fixed? It was the hydro system? Can you take back that engine you bought?
Yep - fixed and running! Thanks.
Not really sure what it was but flushing the hydro system and new fluid and filters did the trick.
Thinking I will just clean up and get the "old" motor running good and hang on to it at this point. Have a few projects in mind down the road where it maybe handy...
/ 22 Ton log splitter "issues" #20
Yeah....I tend to hang on to stuff like that as well...I have 4 hour meters I have purchased recently in my quest to add an hour meter to my stump grinder....I will just keep them...never know when you might need them and they are already paid for.
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
1986 KUBOTA R-400 WHEEL LOADER (A60429)
1986 KUBOTA R-400...
Deere 335P (A53317)
Deere 335P (A53317)
