Lxx60 block heater max temperature?
   / Lxx60 block heater max temperature? #11
Oldoak, share you sentiments, I did add a cab but don't bother w/ block heaters. Had my tractor six years, rarely even use glow plug. Battery is original.
Oldoak - I don't use it to make starting easy... I use it like your last comment suggests - to make the cab warmer faster... period.
majorwager - it was just not plugged in all the way - the extension cord end and the block heater plug didn't like each other - that's fixed. WiFi is strong in the barn - hard wired access point out there. L4760 moved the wet snow like nothing - way more power than the old TC45 ever had.
   / Lxx60 block heater max temperature? #13
Oldoak - I don't use it to make starting easy... I use it like your last comment suggests - to make the cab warmer faster... period.....................................................
Yes, I realize that. That's why I added that last little comment. I wasn't criticizing you. Just adding my experience in cold weather starting. :drink:
   / Lxx60 block heater max temperature? #14
At -5 below Fahrenheit my block heater is hot, as are the pre-heater electrical wraps for hydro filters and fuel filters.
   / Lxx60 block heater max temperature? #15
A word of caution here, modern electrical codes specify GFI for all outside outlets.
Now if it snows or rains you stand good chances that the GFI will kick off the block heater circuit.
It's a bummer.
Local city snow contractor was plugged in but the extension he used was subjected to snow at the connection and he had a cold no start tractor.
GFI simply kicked out, they kick out at the slightest sniff of wet and snow is frozen 'wet'.
We intend to replace all those outside outlets with non GFI's as they are simply a major PIA.
On my tractor I use a wireless remote switch like a car 'key fob'.
I also parallel a witness light bulb* to confirm the heat is on.
Generally I switch 1 hour or so B4 plowing. If the engine is warm then the cab heater will cozy me.
(like I hate driving all bundled up and wearing gloves)
Before that I had a switched outlet with the switch in the clothes closet but I like the wireless better.
* I use an LED night light from the dollar store. (taped over the sensor to make it always hot, like permanant night time)
   / Lxx60 block heater max temperature? #16
Believe Fishpick stores his tractor in enclosed building. Not sure if classified as "wet location", GFI likely not a code requirement, his situation.
   / Lxx60 block heater max temperature? #17
LED lights build into the extension cords let me know the story on my GFI.
   / Lxx60 block heater max temperature? #18
I suppose if Fishpick becomes paranoid that his heater is disconnected, he could easily add a WiFi camera to monitor a thermometer connected to the block heater. Fun spending his money for him........
The WiFi smart plug in the barn reports if it's on or off - so I don't need other light bulbs and whatnot in the barn to turn on... I just need to make sure I plug the flippin plug in ALL THE WAY if I'm using the extension cord that gave me greif...
And I have a WiFi camera in the barn @majorwager - for security more than anything... shoots movement it detects to the cloud and stores everything on an internal SD card - for $20. Check out Wyzecams - love them!
   / Lxx60 block heater max temperature? #20
I just have a flip phone, So way over my pay grade:D
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
New/Unused Electric Golf Cart (A57453)
New/Unused...
Highline Manufacturer BP661-100 (A57148)
Highline...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
Ford 3000 Tractor (A57453)
Ford 3000 Tractor...
2006 JCB  930 MAST FORKLIFT (A58216)
2006 JCB 930 MAST...
