REVERSE OSMOSIS
   / REVERSE OSMOSIS #11
Well why didn't I think of this...
Your post is just obvious now that I read/think about it.
My original issue was just looking at the specs and comparing the numbers and not really thinking about them
The 760 has just about the same bucket cylinder digging force (actually a few more pounds than the 860, 4554lbs vs 4435lbs on the 860) and close to the same dipperstick digging force as well.
The 760 has a digging depth of 91.2 inches vs the 103.2 (1 foot less than the 860)
So really I was a little confused why it appeared they had such a similar digging force but one had more reach.
Your post made it obvious that even though the numbers are similar the 860 has to be stronger in its design in order to still apply that same force further out.
I've got it on order and will be here in the next week or so.
   / REVERSE OSMOSIS #12
I would ask what are your goals with an r/o system?
Is your water not clean enough visually?
Is your water not clean enough chemically/bacterially?(Did you get it tested)
Does it have a funny smell/taste to it?
If you are looking for a good ro system it'll cost you especially if you need a pump to supplement your pressure. ( 40 psi should be min)
Depending on why you need a supplemental system, there are other filtration methods to get your water clean for about the third of the cost of an ro system.
   / REVERSE OSMOSIS #13
If it is just for drinking water look into Brita pitcher or similar. That filter will remove a lot of stuff that makes your water taste bad. If there are biological elements you are needing to remove those filters will not do the job and RO or other higher end like a UV filter is needed.
   / REVERSE OSMOSIS #14
Hey - rekees4300 - I've had frogs AND snakes in my spring. They don't taste bad at all. Its all part of the "country taste thingey".
Generally speaking - there are many multiple ways to treat your drinking water - IF NECESSARY. RO is not considered the best method unless absolutely necessary.
   / REVERSE OSMOSIS #15
LOL ... different strokes for different folks
   / REVERSE OSMOSIS #16
You can check for proper function with a TDS meter (total dissolved solids). R/O water will show considerably fewer dissolved solids than untreated water.
Go to several R/O manufacturing sites and read up on the systems. Prices have really come down in the last 10 years or so. We use it for drinking and cooking.
Yes; check the RO systems out on the Internet. There are filter variances depending water supply and end quality desired. Also note that they have a wash flow over the RO element which may require a lot of water.
   / REVERSE OSMOSIS
World Health Organization does recommend against drinking RO water because it can leach nutrients and minerals from your body. But if you have biologicals in your water, it痴 much better than that. I don稚 have one anymore, but I finally got a precisely spec壇 water softener that gives us very soft water without the 壮oft water taste.
Completely demineralized water does has the ability to destroy a number of materials. Not technically corrosive because it has a neutral pH, but rather has an incredible ability to solubilize minerals and metals.
I agree with that.....that water can act corrosive in spite of having a neutral pH. It does this even without containing any free ions - in fact, that's the definition of "neutral pH. But even neutral pH water is still a freely mobile liquid composed of polar molecules. So even without any ions, neutral water still has a lot of solubility potential just hanging out there ready and willing to solubilize anything it comes in contact with. Minerals and metals are especially vulnerable.
It looks like I'm going to have to put some more time into understanding osmotic membranes before I can understand even a simple RO system. Osmosis works kinda backwards from the kind of filtration that tractors use.
rScotty
   / REVERSE OSMOSIS
Good questions....yes, I certainly should have mentioned goals first. My goal for the RO was to reduce dissolved manganese and sulphates in our drinking water. Both of these are natural to our mineralized water and within the normal limits - but on the high end and I imagine I can taste them sometimes.
So that is why I was put a simple undersink RO system for our drinking/cooking water.
And come to think of it, I should explain our system first. It's probably not that different from other rural systems.
Our well is a shallow well into a sand and gravel deposit a few hundred feet from a mountain stream.
So the source water is similar to that of a natural spring - but it still requires a pump to bring the water uphill to the house.
House pressure varies between 20 and 50 psi, so the pressure should be sufficient for RO.
At the house the water is treated to several stages of screen & paper filtration followed by charcoal filters (in parallel) & a commercial UV anti-bacteriological system (Atlantic UV, Sanitiron). All real standard stuff from Home Depot - except the UV, which is a commercial size.
We also "shock-chlorinate" the well twice a year, and pay to have a water analysis done on the product water about every few years - or if anything changes.
Last fall I added a simple GE undersink RO with its own faucet. It seems to work. Our basic water tastes good, but the RO seems to taste slightly better. So I was happy until I sent a sample to the lab for testing a few months later, I was surprised to find how much the RO water varied from the well water. Well water analysis remains the same, and in the RO water the mangaese was down sure enough. But the RO water was higher in some other things - including sodium & total dissolved solids (TDS). I wonder why? The lab had no idea, and they were surprised. They even re-ran another sample for free.
So that's when I realized I didn't actually know that much about RO systems. According to the lab director, there is no way that an RO system could fail to lower the sodium and TDS. And so that is why I posted here.
What do others find when they do a water analysis on their drinking water?
rScotty
   / REVERSE OSMOSIS #19
I just had a water treatment system and RO installed. Our water test indicated arsenic, manganese, and iron. Based on the test, the water treatment guys installed a water filter and water softener for the whole house, and an RO for the drinking water only.
You need the right filtration for whatever the contaminants are. Start with a good comprehensive water test.
   / REVERSE OSMOSIS
Yes, that's what I did. Not just one test but a series over the years. Then I added the RO, and it was the test of the RO water that surprised me.
Have you tested the water since adding the treatment system?
BTW, all the water tests seem cost about the same - and none are cheap. I pay about $200/test depending on what boxes I check to look at. I'd recommend your local universisty for the testing - they are least likely to have a bias. Out here in the west, most Ag schools have a soil and water testing dept.
rScotty
2000 Waba Commercial Trailer (A51692)
2000 Waba...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
DAEWOO MG 250-3 (A52472)
DAEWOO MG 250-3...
