2 Tractors or 1 Tractor? What do you own??
   / 2 Tractors or 1 Tractor? What do you own?? #22
As many as wifey will allow...
Gottcha!
   / 2 Tractors or 1 Tractor? What do you own?? #23
I guess I have three but since two are garden "tractors" only one really. My vote is, average small land owner one, logger two, farmer ????. Two acres and no forestry work to be done one.
   / 2 Tractors or 1 Tractor? What do you own?? #24
Takes me 4 to get it done. 2 Montana (farmtrac 675) (one is 4x4), Kubota L35 Bhoe, and a Cablea's (Tym) 45h. The Montana's are probably the best tractors I have ever owned.
   / 2 Tractors or 1 Tractor? What do you own?? #25
The Little Kubota was sold in 2015.
Just a hobby farm also, with Livestock and Critters, etc.
   / 2 Tractors or 1 Tractor? What do you own?? #26
For what you do, I would personally sell both the smaller JDs and the BHs, buy your 60 to 70 hp JD and batwing, making sure it had a FEL with SSQA. Changing implements is a snap with the right equipment - it is only when it is a long drawn-out affair that one wishes for another tractor already hooked up for what you want to do. SSQA and QA for the TPH and you will never spend more than ten minutes changing.
   / 2 Tractors or 1 Tractor? What do you own?? #27
my grandpappy had a saying....if you get everything done today...what are you going to do tomorrow???? i have 4!!!! for a 100 acres..
   / 2 Tractors or 1 Tractor? What do you own?? #28
I currently have 3 tractors, but the BXs main job has always mowing grass 98% of the time. I now pay my buddy that has a grass cutting service to do that which has been a great time saver for me and helps my wife while I am away at work by not having to worry with it. I will likely trade the BX for more implements for the larger tractors since the BX still has good value and I don't have much need for it any longer.
That is a very nice setup. I am not familiar with the Jbota brand. Can you tell us about it? :wink:
   / 2 Tractors or 1 Tractor? What do you own?? #29
I have two tractors. I rebuilt the '52 Ford 8N that I've had for many years and it performs very well. I keep a 5' finishing mower attached to it year round. I cut the front areas/yard with it. About 5 acres. I purchased a pair of implement rims and put car tires on them. They work fantastic as they float on the ground instead of digging in when turning. I purchased a L2501 Kubota about 3 years ago and use it most of the time for bush hogging and FEL work, on the rest of my 70 acres. I have a 2 bottom plow that I intend to put to work when I retire this summer. Best of both worlds....Ford/Kubota. Guess if they had a baby, it would be called a Forboata :laughing:
   / 2 Tractors or 1 Tractor? What do you own?? #30
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2017 Ford F-650 (A56858)
2017 Ford F-650...
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
2013 Magnum Power MLG08 Towable Runway Closure Marker Light Tower (A55851)
2013 Magnum Power...
