TS 100 Master cylinder leak
   / TS 100 Master cylinder leak #1
musselmark
grand tracadie PE
'05 NH TN75DA
A buddy has a TS 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
   / TS 100 Master cylinder leak #2
Re: TL 100 Master cylinder leak
A buddy has a TL 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
The later years were TL100A. In either case Messicks shows the master cylinder at $326. Don't see any exploded view that shows parts for it.
Actually I just found a kit on ebay for 67 bucks.
Cheapest brake master I could find on ebay was around 400 Canadian delivered. The clutch ones are cheap
   / TS 100 Master cylinder leak #7
G'day if you are going to rebuild one then do both while you are in there and be sure to use the correct fluid for it I think it should be a mineral fluid IIRC
Jon
43021 (A51691)
43021 (A51691)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Safety Basket (A50121)
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2006 Poly-Coat Tanker Trailer (TITLE) (A50774)
2006 Poly-Coat...
