TS 100 Master cylinder leak
   / TS 100 Master cylinder leak #1
musselmark
grand tracadie PE
'05 NH TN75DA
A buddy has a TS 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
   / TS 100 Master cylinder leak #2
Re: TL 100 Master cylinder leak
A buddy has a TL 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
The later years were TL100A. In either case Messicks shows the master cylinder at $326. Don't see any exploded view that shows parts for it.
Actually I just found a kit on ebay for 67 bucks.
Cheapest brake master I could find on ebay was around 400 Canadian delivered. The clutch ones are cheap
   / TS 100 Master cylinder leak #7
G'day if you are going to rebuild one then do both while you are in there and be sure to use the correct fluid for it I think it should be a mineral fluid IIRC
Jon
Genie GTH-844 (A50120)
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
