Do You Really Need the Steering Wheel? Ford Recall
   / Do You Really Need the Steering Wheel? Ford Recall #2
I think all of the automobile companies have stepped up and took care of recalls better than in the past. As a side note, an awful lot of people pull themselves into the vehicle by grabbing the steering wheel, really a bad habit.
   / Do You Really Need the Steering Wheel? Ford Recall #3
I think all of the automobile companies have stepped up and took care of recalls better than in the past. As a side not, an awful lot of people pull themselves into the vehicle by grabbing the steering wheel, really a bad habit.
Might be a good way to tell if your steering wheel is loose though. :D
   / Do You Really Need the Steering Wheel? Ford Recall #4
I think it would be a good habit. If instead of pulling you into your truck you pull the steering wheel off then that's a sign that it's too loose.
I bet Ford is blaming it on the Nut behind the wheel!! :)
   / Do You Really Need the Steering Wheel? Ford Recall #6
A professional can get by without it. They're over rated! :thumbsup:
   / Do You Really Need the Steering Wheel? Ford Recall #7
That's how you keep your ford from being stolen......you just take the steering wheel with you!
SR
   / Do You Really Need the Steering Wheel? Ford Recall #9
Or you need to lose a lot of weight.:)
Steve
   / Do You Really Need the Steering Wheel? Ford Recall #10
There was an old mountain man neighbor (RIP) that used to drive an old station wagon around with a pair of vice grips in place of a steering wheel...!
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
CATERPILLAR 420E BACKHOE (A52707)
CATERPILLAR 420E...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
378721 (A54865)
378721 (A54865)
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
