Do You Really Need the Steering Wheel? Ford Recall
   / Do You Really Need the Steering Wheel? Ford Recall #2
I think all of the automobile companies have stepped up and took care of recalls better than in the past. As a side note, an awful lot of people pull themselves into the vehicle by grabbing the steering wheel, really a bad habit.
   / Do You Really Need the Steering Wheel? Ford Recall #3
I think all of the automobile companies have stepped up and took care of recalls better than in the past. As a side not, an awful lot of people pull themselves into the vehicle by grabbing the steering wheel, really a bad habit.
Might be a good way to tell if your steering wheel is loose though. :D
   / Do You Really Need the Steering Wheel? Ford Recall #4
I think it would be a good habit. If instead of pulling you into your truck you pull the steering wheel off then that's a sign that it's too loose.
I bet Ford is blaming it on the Nut behind the wheel!! :)
   / Do You Really Need the Steering Wheel? Ford Recall #6
A professional can get by without it. They're over rated! :thumbsup:
   / Do You Really Need the Steering Wheel? Ford Recall #7
That's how you keep your ford from being stolen......you just take the steering wheel with you!
SR
   / Do You Really Need the Steering Wheel? Ford Recall #9
Or you need to lose a lot of weight.:)
Steve
   / Do You Really Need the Steering Wheel? Ford Recall #10
There was an old mountain man neighbor (RIP) that used to drive an old station wagon around with a pair of vice grips in place of a steering wheel...!
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
New/Unused Hydraulic Thumb for CFG Mini Excavator (A54865)
New/Unused...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
