Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!!
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #21
Re: Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!
:thumbsup: Yep, tuned in and waiting. :D
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #22
Same, waiting
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #23
Same, waiting
OK... Let's see if I can do this in a cohesive/succinct/complete/factual manner...
1. The order for TWO (additional) EA implements (62" gear-drive Roto-Tiller/60" 75HP Rotary-Cutter/Bush-Hog) was submitted 02/23/18 at 1133 hrs. and it was delivered today/3/23/18 at 1330 hrs...
2. Delivery was relatively uneventful with excellent coordination between OEM/Carrier/Destination (rural Central Florida farm)... This is my second farm-delivery of implements (2 each) and EA is using good/excellent carriers... With minimal scratches/dings, great communication, very competent/helpful drivers/support-staff...
3. I have not had a chance to use either new implement...
4. The new EA 60" 75 HP rotary-cutter/bush-hog appears to be a BEAST... The construction/materials/paint-finish is everything I was told it would be... I am unable to make a final connection/working-demonstration today due to time constraints and a small issue with my Land Pride Quick Hitch Model 15 floating-top-link connection (apparently I need a kit/adapter)... My tractor is a KUBOTA 4701DT and it is capable of handling a 6' rotary-cutter but I ordered this beefed-up 5' EA model because of the overall/outside dimensions (wanting to keep them within the 6' range)... I am clearing/maintain boundaries/fences and do not want to go beyond the width of my tractor/rear wheels even if the rotary-cutter does not mow all the way to the line/fence... I have seen too many snagged field-fences that are not fun to mend in the Central Florida Summer sun/humidity... I get as close as my back wheels and let my friend Herbie (herbicide) do the rest...
I will be posting more info/pics when I get this rig fully connected/running... 5FtEARotaryCutter1.JPG 5FtEARotaryCutter2.JPG 5FtEARotaryCutter3.JPG
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #24
Good pictures, worth staying tuned for. :thumbsup:
Still tuned for more. :D
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #25
It may be the way the picture is but it looks like the chains are a little short to me. I am interested in the 6 ft model so I am tuned also. Nice setup good luck.
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #26
Looks like it has “ Landshark” on it. That another name for EA brand or what?
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #27
Chains do look short compared to others I’ve seen. Land shark is EA new line of implements.
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #28
EA also makes and sells Landshark brand
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #29
I did all the preliminary/necessary connecting/adjusting-fitting-leveling/lubricating/greasing today... Awaiting a Land Pride Floating Top-Link Kit for my QH15 ("The EA rotary-cutter has a rigid 3-point-hitch-frame where some others have an articulating top-link… My LP-QH15 requires a floating-top-link installed on either the quick-attach QH15 3-point hitch top-link or as an integral articulating member of the rotary-cutter frame… So, I am unable to fully connect/utilize the EA rotary-cutter until I receive/install the proper ‘Land Pride QH15 Floating Top Link Kit’ [ordered from Messick’s Sat. 24 Mar. $37.00 including s/h"])… I will be sure to post some action shots when they happen (prolly mid-week)... As for the appearance of the front/rear chain-guards being a tad short, I made some adjustments to lower them a full 1/4" but predicting they are going to allow good/excellent relief of cut debris while affording the necessary protection ("The rotary-cutter chain guards now hang approx. ¼” lower and some may find them [still] slightly short but I am going-out-on-a-limb to say they will be fine… When I get this rig churning-out-meaningful-work I am predicting that the shorter chains will BETTER allow the cut debris to exit/effluent/exhaust")... The new 60" roto-tiller required some assembly of the 3-point-hitch-framework and the usual lubrication/grease... It too is ready to rumble... Stay tuned...FrontChainGuards.JPG Roto-Tiller2.JPG RotaryCutterZerk1.JPG RotaryCutterGearOil1.JPG
   / Bush Hogging HOW-TO VIDEO With THE ETA 60" BRUSH CUTTER & Our New Video Tractor!!!! #30
Didn’t know that. Thought it was a brand they carried. Not made. Good to know.
1994 International F-8100 Roll Off Truck, VIN # 1HTHCAUR7RH595438 (A54865)
1994 International...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A56129)
2008 AAR MOBILITY...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
(4) New Winch Straps (A54865)
(4) New Winch...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A56129)
2007 FREIGHTLINER...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
