Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,581
I have the Uniforest 35E (predecessor to the 35M). They must have changed the design. I did not have to lay the winch on it's back when I changed cable. I left it on the tractor, unwound the cable all the way, removed a small access panel/screen to unhook the cable from the drum. Threaded the new cable in and attached it, then spooled it back up.
One helpful trick: do not unroll the new cable I rigged up a pipe to act as an axle for the new roll, then pulled it off that as I wound it onto the winch drum. You want to wind with the existing curl of the cable. If you are standing near the left rear wheel of your tractor looking at the winch: picture it coming off the new roll counter clockwise as it winds onto the drum also counter clockwise. (It should look something like a cassette tape, wincing off one spook and onto the other. It should not make an "S" shape, as this will wind against the existing curl in the cable). Winding with the curl, rather than against it minimizes the cables tendency to self-unwind and make a bird's nest on your drum if there is no tension on the cable. (I hope that description was clear.)
After reading this I went out and saw what you are referring to. Somehow I had overlooked that, in my hurry to get back to work. I measured my remaining cable today and have just 100' left on the spool from what was originally 230'.
When my front end comes up 3' off ground the blade on the winch stops the tractor from going any further, the rear wheel just dig holes.
As far changing cable being a pain, I thought Fransgard was the the worst till I did a few changes, before I had to unhook the hole winch from tractor and take off every part that would come off and still had a hard time to get the spool out, so's to make changing out cable easier. Or if not quick on the draw when the cable breaks near the winch, the rest of the cable will whine inside the winch and that's what happen to me last week, 36' went inside winch, enough to finish up if the cable didn't go inside.
Here's some pictures of the change, theres two 1/2" fine thread case hard bolts on both sides of that front winch frame marked in red, take off the one big nut and then those four bolts and the spool slides out, before the front frame was welded between the white lines. Had my son give me a hand.
View attachment 544468 View attachment 544469 View attachment 544470 View attachment 544471 View attachment 544484
You could be right about not going over backward, I was never about to try it. As soon as the front starts to come up I hit the clutch. You're picture brings back memories. I had a pre-2800 Fransgard that I rebuilt, worked the crap out of it and sold 10 years later. In the first few years that I had it I took the drum down to Brake Service and had the clutch side turned, replaced all 8 bearings and put new cable on it. The organic part of the clutch could be replaced, and while I never changed it I did need to reattach it with brass bolts as the rivets had rusted or broken. I also replaced the chain, although it really should have had new sprockets. Mine didn't have the block which you mention to hold the cable; instead it went into a piece attached to the drum, and worked similar to the cable end which we discussed earlier.
Another poster just pointed out to me that on my new one there is a window to access the spool, so changing won't be as bad as I thought.
I'm glad that I am not the only one who breaks cable; a couple years ago I picked up a very used Farmi down in Belfast which turned out to be way too heavy for my 275; yet the very first time that I used it I broke the cable. I took the winch off, leaned it up against a tree, put it on Craigslist and sold it for what I paid for it.
   / Tractors and wood! Show your pics #5,583
Of the PTO winch brands that I've seen here on TBN, all have some sort of top pulley guide like my Fransgard which makes me wonder if theres a better pulley guide on a better winch?
In ten years this is the second time I rewelded this gude hole, the first time I just put some weld in the grooves and clean up with die grinder. This time I filled in all of hole, or the whole hole and redrilled with 3/8" as shown, then after a nights sleep I decided that 3/8" is not big enough for 8 mm cable, so I up the size to just under 7/16" and still sleeping on that. I was thinking the original hole was 1/2" but dont see why a 5/16 (8mm) needs that big of hole.
   / Tractors and wood! Show your pics #5,584
I needed to retrieve this oak log from a spot out back that wasn't dry yet,
so I loaded it on my snowmobile trailer and my wife pulled it out with the Kubota,
The log is 24" x 8' 6" long... Looks like it will end up on my BSM, as my helper wants the lumber out of it...
SR
   / Tractors and wood! Show your pics #5,585
SR
Nice pitures SR, just wish I could zoom in........I see you have a couple leaning trees in the background, we gotta get them taken care of.
   / Tractors and wood! Show your pics #5,586
Thanks oldpath...
Those "leaners" are Aspen and I have about a thousand of them leaning or down! I'll never get them all!
SR
   / Tractors and wood! Show your pics #5,587
A 1000 Aspen leaning and down, wow that sounds like a 100 cord of what to do with wood, maybe paper mill, dont think Aspen makes good firewood and who wants 50,000 brd ft of 2x4s, could have someone come in and cut for bio-mass chips.
I have about 25 Aspen that are 12'' on the stump and by the looks of the rough bark, think some have rot in them, when I finish firewood they will come down and sit for a year then saw into something, I used a fair amount of it in my shop when I built it 5 years ago.
   / Tractors and wood! Show your pics #5,588
I did cut quite a few of them, but now I'm focused on better firewood and it takes up any wood cutting spare time that I have. I'll be back at it on Sat... Once I get these last few oaks out, I'll be moving into some fairly big hard maples...
I don't want the money bad enough to have skidders in here cutting my lanes ect.. up all to he!!, so those Aspen will mostly end up being wild game habitat... I'll try to get you some picts...
I don't know if there is a thousand of them, but there's for sure many hundreds, probable a thousand...
SR
   / Tractors and wood! Show your pics #5,589
SR
Aspen make good firewood. You should get them all out and bring them up for your winter on fire wood. No point in letting them rot
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
ASCO Transfer Switch (A52377)
ASCO Transfer...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
