BlackOps
man really nice job!!!!
If you use 6 cords per year why are your sheds 4 cord?
Valid question. First shed I built was an open front/back...just had two end walls. Probably held about 2 cords. It didn't hold up to moving around (empty) different locations on the farm where I would be thinning or clearing. So after a some years of this proto-type, I built a couple of the 4 cord sheds, built them quite a bit studier.
Then I really started keeping up with the amount of out wood use....and decided a couple more would do the trick for 2-3 years worth of wood in the dry. I suppose I could have built them bigger, but this size is about as big as I care to move. Also some years it's 5 cords....I don't think there is a perfect size, so this is it.
What do you use for the skids? do you spring for PT? locust? white oak?
You always impress me with your organizational skills, and your ability to plan ahead. By the time I get done thinking of what to do, you've already finished doing it!!!!
