Just purchased a 1963 Massey Ferguson 202 with...
   / Just purchased a 1963 Massey Ferguson 202 with... #11
I just purchased a model 204 with Revers-O-Matic. I have not yet seen the backhoe because it is stored elsewhere (resurrecting that is sure to be an adventure). Loader is model 102. Serial number seems to indicate my tractor is a 1959 model. The learning curve begins.
Post up some pics when you get a chance. We love pictures!
I pulled the gas tank, installed a new sediment bowl assembly , installed the tank. But I neglected to copy where the 2 sending unit wires on the tank attach to the tractor. Anyone know?
Frank
And I want to mention it is a 12 volt positive ground.
Frank
   / Just purchased a 1963 Massey Ferguson 202 with... #14
And I want to mention it is a 12 volt positive ground. Frank
Fuel level sender on mine was busted when I got mine, can't help ya there.
You sure it's positive ground? Especially being a '63. Mine is 12v negative ground and so is my cousins '58 202.
Positive ground unless someone installed the battery wrong............. The positive terminal cable is attached to the tractor frame and the negative terminal cable is attached to the solenoid.
Frank
Tomorrow I will look at the ignition coil to see wether the positive wire or negative wire goes to the distributor. Which ever one does, that痴 also the battery ground.
Frank
I have solved why I did not see any pictures. My iPhone will not allow this. So I went on my laptop, which I have not used in a year or 2 and bingo w there they are. I will post pictures of my machine later.
Frank
Frank
here it is
On the ignition coil the wire from the negative post goes to the distributor. From most of what I have read on the Internet ... this means the tractor is a negative ground.
Whereas mine had the cable from the positive post of the battery attached to the ground making it a positive ground.
Now I do not know what is correct ....... wether it is a positive or negative ground.
Frank
Does anyone have a wiring giagram for a 1963 Massey Ferguson 202 with a gas engine ?
Frank
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
