2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth?
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #1
klwinter2
I am looking at a clean 2008 RTV1100 with 1700 hours.
What is the value?
Is 1700 worn out?
Did the 2008 have any design flaws?
Thanks..
Kenneth
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #2
I have a 08 900. There's no flaws unique to the model you are looking at.
The value is subjective. Condition? Tires? Location?
I'd think it's worth $10K if it's in very good condition and parked inside.
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #4
What is the value?
Is 1700 worn out?
Thanks..
Kenneth
1700 hrs. is now way near worn out on the engine. If HST is still functioning properly and it looks good for wear and tear, it may be worth the price, but I would over $9000 for it but only if everything works well. Lots depends on the accessories also- does it have a winch (deduct $300 if not), a GLASS windshield ($800 option in 2009)with a cab I would assume the WS is glass, if plastic windshield is it scratched up or crazed, does it have the doors, an AC and heat (deduct $1000 if no doors) deduct another $1000 if no HVAC.
If it has a cab, with doors and working heat and AC then it is worth $10k if not maybe 8K if everything looks in good shape. A bad transmission is a run from the deal issue and could well cost you $5K+ to fix.
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #5
Where do you get the idea it is worn out at 1700 hours on the engine ?
David
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #6
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #7
9-10k
check for slop in the u-joints between the engine and trans and also down to the wheels.
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
377811 (A48836)
377811 (A48836)
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
