2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth?
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #1
klwinter2
I am looking at a clean 2008 RTV1100 with 1700 hours.
What is the value?
Is 1700 worn out?
Did the 2008 have any design flaws?
Thanks..
Kenneth
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #2
I have a 08 900. There's no flaws unique to the model you are looking at.
The value is subjective. Condition? Tires? Location?
I'd think it's worth $10K if it's in very good condition and parked inside.
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #4
What is the value?
Is 1700 worn out?
Thanks..
Kenneth
1700 hrs. is now way near worn out on the engine. If HST is still functioning properly and it looks good for wear and tear, it may be worth the price, but I would over $9000 for it but only if everything works well. Lots depends on the accessories also- does it have a winch (deduct $300 if not), a GLASS windshield ($800 option in 2009)with a cab I would assume the WS is glass, if plastic windshield is it scratched up or crazed, does it have the doors, an AC and heat (deduct $1000 if no doors) deduct another $1000 if no HVAC.
If it has a cab, with doors and working heat and AC then it is worth $10k if not maybe 8K if everything looks in good shape. A bad transmission is a run from the deal issue and could well cost you $5K+ to fix.
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #5
Where do you get the idea it is worn out at 1700 hours on the engine ?
David
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #6
   / 2008 RTV 1100 enclosed cab - 1700 hours. Whats it worth? #7
9-10k
check for slop in the u-joints between the engine and trans and also down to the wheels.
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
BUSH HOG 7007 LOT IDENTIFIER 99 (A53084)
BUSH HOG 7007 LOT...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
CAT Skid Steer (A50322)
CAT Skid Steer...
BY VALLEY INDUSTRIES 60 R22 823 LOT IDENTIFIER 221 (A53084)
BY VALLEY...
Pair of New 700/40-225 Alliance Tires with Rims (A53472)
Pair of New...
