OP
Lineman North Florida
Elite Member
- Joined
- May 12, 2008
- Messages
- 2,562
- Location
- LaCrosse Florida
- Tractor
- Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
Eddie, I'm getting a little closer to laying the floor and have went with everyone's advice and decided to go with the 25/32 Advantech tongue and groove, my question is if I read you right when I slide these sheets together I will lose about a 1/2" of width coverage on every sheet, and since my building is 20' wide after laying 5 sheets I will lose about 2&1/2" which will put me cutting a narrow strip at one edge which won't matter as it will be under my sole plate of my outside wall. Is this right? Charlie.No tongue and groove sub flooring that I'm aware of is going to give you 4x8 once slid together. That measurement is for the outer edge of the sheet including the tongue. Once you slide it together, it will be half an inch short, which adds up with every sheet.
Most floor joists are on 24 inch centers. Going with 19.2 inches will give you a lot more strength with minimal expense. But if it's a small cabin, 16 inches is even better. 19.2 is marked on every steel tape with a red diamond for framing.
As mentioned, Advantech is the best sub flooring out there. It's the same price as the plywood, which makes it a no brainer.
