Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,771
It's not my work but somebody did a nice job welding it. Was there when I bought it used.
gg
Thanks for sharing that, I need to do something similar. I'm thinking about attaching it to angle iron which I can then bolt inside the guard.
Presumably I make the puddle on the heavier steel, then bring it to the ES. I need to practice my welding skills first though.
   / Tractors and wood! Show your pics #5,772
Presumably yes. But if you just have stick like me it isn't easy on light ES like that. I cheat and braze weld it with a bronze rod and O/A torch. Very easy and you don't burn off 2 out of 3 tacks.
gg
   / Tractors and wood! Show your pics #5,773
gg
I think that I will drill holes in 3/4" angle which I can weld onto the guard, then bolt the expanded steel to that. Just thinking it out right now, there's still too much snow to get to my welder.
   / Tractors and wood! Show your pics #5,774
Split a bunch of 4-foot black birch logs with wedges, maul, and Fiskars splitting ax. Will be great burning in 3 years.
   / Tractors and wood! Show your pics #5,777
That seems like a lot of work. Why not cut them shorter and put them through a splitter?
   / Tractors and wood! Show your pics #5,778
Fence rails?
   / Tractors and wood! Show your pics #5,779
I've built a bottle cage out of ES and a few other things. You basically just tack it. Put the ES inside some angle iron for a clean finish and less bleeding in the future.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
