Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,771
It's not my work but somebody did a nice job welding it. Was there when I bought it used.
gg
Thanks for sharing that, I need to do something similar. I'm thinking about attaching it to angle iron which I can then bolt inside the guard.
Presumably I make the puddle on the heavier steel, then bring it to the ES. I need to practice my welding skills first though.
   / Tractors and wood! Show your pics #5,772
Presumably yes. But if you just have stick like me it isn't easy on light ES like that. I cheat and braze weld it with a bronze rod and O/A torch. Very easy and you don't burn off 2 out of 3 tacks.
gg
   / Tractors and wood! Show your pics #5,773
gg
I think that I will drill holes in 3/4" angle which I can weld onto the guard, then bolt the expanded steel to that. Just thinking it out right now, there's still too much snow to get to my welder.
   / Tractors and wood! Show your pics #5,774
Split a bunch of 4-foot black birch logs with wedges, maul, and Fiskars splitting ax. Will be great burning in 3 years.
   / Tractors and wood! Show your pics #5,777
That seems like a lot of work. Why not cut them shorter and put them through a splitter?
   / Tractors and wood! Show your pics #5,778
Fence rails?
   / Tractors and wood! Show your pics #5,779
I've built a bottle cage out of ES and a few other things. You basically just tack it. Put the ES inside some angle iron for a clean finish and less bleeding in the future.
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
