White plastic screen fell into gas tank on XG3140
   / White plastic screen fell into gas tank on XG3140 #11
Get a Mr Funnel and never look back. That will take out everything water included. They’re a bit slow and awkward to use but nothing gets through
   / White plastic screen fell into gas tank on XG3140 #12
Great idea. Those filters look awesome and do indeed block water.
   / White plastic screen fell into gas tank on XG3140 #13
Same dang thing happened to me a few days ago on my R3039. I’m just gonna leave it in there. Shouldn’t hurt a thing.
   / White plastic screen fell into gas tank on XG3140 #14
Mine on my smaller one is about to do same. It is visibly deteriorated at ~60ish hrs on the machine. Never jammed a fuel nozzle in it or had a "save the planet by spilling diesel everywhere" spout poke it from a slip. Mine really looks like the plastic/nylon it's made from is just getting eaten up from being exposed to fuel!
Need to find a replacement but hate to order an OEM part if it will have same issue in short order. Dislike the idea of running without - newish fuel cans and I already notice a little crud settled in bottom. No idea how that gets in there - I buy fuel from local gas station from auto diesel pump, keep in sealed 5 gal cans, and never place the spout or cap directly on ground. Kind of careful with every step of the fuel transfer process, but still have crud.
Just 2 weeks ago went thru PIA process of dumping two 5 gal cans of new diesel into empty clean cans thru a 120 mesh paint strainer because I could see some crud inside the cans....
   / White plastic screen fell into gas tank on XG3140 #15
If the "lost" strainer was anything like the one I had on my JD G100 riding mower - it would be good for stopping 3/4" gravel and bigger stuff. About two months into ownership, I jerked the little plastic strainer out and trashed it.
   / White plastic screen fell into gas tank on XG3140 #16
Just went out and checked my strainer. Fairly wimpy and cheap but it has a fairly fine mesh. I do think I will get a Mr Funnel with the water-block feature. Can't be too fussy when it comes to keeping your fuel clean.
   / White plastic screen fell into gas tank on XG3140 #17
Those range for $18 - $55 on amazon. Is there a difference other than flow rate? Since I'm on 5 gal cans with enviro-spouts, the smaller 3.5 gpm is probably sufficient?
Description so no replacement parts? You never change the filter?
   / White plastic screen fell into gas tank on XG3140 #18
No replaceable parts and you just clean any trapped water and crud out of funnel after use. Guess I'll try one since you can never have to many funnels.
   / White plastic screen fell into gas tank on XG3140 #19
I ordered one from Amazon. I'd much rather fool with that filling than filtering fuel cans with a paint strainer again.... And then can just remove the white plastic oem screen before it completely fails and goes in the tank.....
   / White plastic screen fell into gas tank on XG3140 #20
Have you see the EZ-Pour nozzles? I’ve converted 3 of the enviro-spout cans and they’re awesome! They even have a high flow version that I use on my mower gas can.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2019 PETERBILT 567...
Informational Lot - Shipping (A53473)
Informational Lot...
