RNeumann
Elite Member
Do you own a logsplitter? I use mine for pressing things all the time. Got a piece made to slip over the wedge and protect its edge (and to not cut into the steel Im pressing)
Smart!
I might have to fab something up and give it a try. Wife's been after me to replace the frame on one of our metal frame benches that has started to disintegrate.Do you own a logsplitter? I use mine for pressing things all the time. Got a piece made to slip over the wedge and protect its edge (and to not cut into the steel Im pressing)
I do the same thing - I haven't had the need for a dedicated press so I built a slip over for my splitter and it works okay for some gross work - kind of tricky to do delicate pressing though.
Still use my splitter for pressing- in addition to the new press.
about a week ago decided to straighten a bumper pull utility trailer's axle that I built out of an old boat trailer.
It was much easier to use the log splitter with add on push plate and a rail road rail for the axle to sit against for pressing the bend out of it caused by PO using the axle as a (jack) point.
The log splitters work great -but a deft hand is needed due to the hydraulics being under engine power.
It can be easy to (overdue) it in just a second -even feathering the spool valve
Here is a pic of the press plate I made for mine, if I were to do it over a larger area for the flat surface would probably have been a good idea but used what was around at the time.
View attachment 547855 View attachment 547856
Sure some of the other posters have some great ideas for a pusher plate to for Dftodd
The style of my first picture is a death trap when it comes to press design. This design is also fixing to be outlawed in the shop's for the company I work for.
The support tubes next to the springs are a week link. Which I can attest to since I killed ours with a torch after it tried to kill me.Thankfully when the arms bent and it spit the shaft out, it went the opposite direction And tried putting the shaft through the wall instead. It dented the siding and shook the building when it hit the wall. Not to mention the bang, which got everyone inside the building into the shop to find out what happened
